Date/Time: Tue, 22 Apr 2025 07:36:27 +0000
Sum Bid Pull/Stack and Sum Ask Pull/Stack - setting
View Count: 193
[2025-01-28 15:01:33] |
User75949 - Posts: 130 |
In the Numbers Bar Calculated Values 2, I see this interesting calculation together with "Ask/Bid Pull/Stack Sum Diff" but I see it only works with ALL Pull/Stack data available, https://www.sierrachart.com/index.php?page=doc/NumbersBars.php#CalculatedValuesSubgraphDescriptions:~:text=Bid%20Pull/Stack%3A-,This,-displays%20the%20sum%20of there is not the possibility to select how many levels should be considered in the calculation. If I go in the Chart>Chart Settings >Market Depth and I limit the number of levels nothing changes. Is there the chance to select the number of Dom levels we can consider in this calculations in any other way? If not, is there any chance that you can introduce this possibility in one of your next release? regards R. |
[2025-01-28 17:04:27] |
Refer to the following: Global Trade Settings Windows: Maximum Bid/Ask Market Depth Pulling/Stacking Levels (Global Settings >> Chart DOM Settings >> Other >> Other Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-29 09:29:08] |
ok thank you, so it is a general setting, if I need to set a different setting for another financial instrument (each one is different) do I need to open another instance? If it is in this way it is a pity because all other things can be setted singularly on a chart eg. depth levels in Chart Settings "Number of Levels for Bid/Ask Depht Calculations", couldn't be added here in the future? tks regards R. |
[2025-01-29 14:17:19] |
Sébastien - Posts: 58 |
Yes you need to use another instance to use different max levels of Pull/Stack. As you said, it's a pity. I've seen a few posts on the Support Board asking for making this parameter a Chart Parameter instead of an Instance Parameter... but for now without success. I also struggle with this issue because using multiple instances doesn't allow to use keyboard shortcut like Re-center trade DOM scales and Clear recent Bid/Ask volume - all symbols efficiently. Making Keyboard shortcut working through multiple instances would fix this inconvenience, but making the Max Pull/Stack Level a Chart Parameter would be a better solution I guess. |
