Date/Time: Tue, 22 Apr 2025 06:57:05 +0000
Clarification needed for Trailing Stop orders with Teton Order Routing
View Count: 156
[2025-01-28 14:36:32] |
User512353 - Posts: 65 |
On page Sierra Chart Teton Futures Order Routing it writes: "Trailing Stop orders are still always managed locally on the Sierra Chart client side." Does this mean that: A) Trailing Stop orders are sent to the server as 'non-trailing' and if the local SC detects that based on the trail offset the order needs to be adjusted, it will send the adjustment to the server. B) Trailing Stop orders are NOT sent to the server and if the local SC detects that the stop price is hit, it will then send it to the server for execution. C) Anything else. ??? |
[2025-01-28 15:15:15] |
Sierra_Chart Engineering - Posts: 19293 |
It works this way: A) Trailing Stop orders are sent to the server as 'non-trailing' and if the local SC detects that based on the trail offset the order needs to be adjusted, it will send the adjustment to the server. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
