Date/Time: Tue, 22 Apr 2025 06:57:06 +0000
Window shifts when zooming in.
View Count: 99
[2025-01-27 21:10:09]
User639783 - Posts: 1
I have a heatmap chartbook I downloaded. When I click and drag the left on the time axis to zoom in on the heatmap so I can look closer at the data with more spacing between points (same as pressing the arrow up key)(so I'm increasing the bar spacing I believe?), the whole window shifts left with it until everything is off the page. How do I drag the time axis left without dragging the whole chart off the screen? Does that make sense?
https://www.sierrachart.com/image.php?Image=1738011982936.png
https://www.sierrachart.com/image.php?Image=1738012133427.png
https://www.sierrachart.com/image.php?Image=1738012159139.png
https://www.sierrachart.com/image.php?Image=1738012183954.png
[2025-01-28 15:48:40]
John - SC Support - Posts: 39395
We do see that this is the case when dragging the time scale.
The only suggestion we can make is to use the "Page Up" key rather than dragging the time scale. This keeps hte right-most bar in its position.
