Date/Time: Tue, 22 Apr 2025 07:02:55 +0000
Changing fonts on the add study dialogue
View Count: 77
[2025-01-27 19:07:19]
User173763 - Posts: 7
Hi Support,
I want to configure the fonts on this dialog to be much bigger. When i right click and select the study option on a chart. That is the pop - up that allows you to add studies. Unfortunately can't find it
Thanks!
imagedialogbox.png / V - Attached On 2025-01-27 19:07:16 UTC - Size: 62.92 KB - 19 views
[2025-01-28 15:30:29]
John - SC Support - Posts: 39395
The font for the "Chart Studies" window is not changeable within Sierra Chart. That window, and others like it, use the font size set by the operating system.
