Date/Time: Tue, 22 Apr 2025 06:51:31 +0000
Daily volume and Range percentage
View Count: 117
[2025-01-27 18:56:56] |
Relleon - Posts: 1 |
Hello dear sir/madam, I would like to add to my 1min chart study, which would show how much volume was traded in a current day since 00:00 compared to the average volume that was traded for X days before for example 20 days. Also i would like to have same percentage for daily range. If symbol used to make a daily change 300 points in a day on average for 20 days i would like to know how many % is already done of this average move. Thank you Sincerely, VN |
[2025-01-28 15:26:55] |
Use the "Relative Volume" study to get this information. Refer to the following: Relative Volume For the Daily Range, you can use the Relative Volume study as well. Note the section for "Basing Relative Volume Study on Another Study for Non-Volume Comparisons" in the link given above. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
