Date/Time: Tue, 22 Apr 2025 06:48:47 +0000
Missing
View Count: 129
[2025-01-27 17:02:50]
maxm1987 - Posts: 119
Hello sierra
im trying to set up my charts to be able to right click to add symbol alerts. However under:
global settings -> customize chart short cut menu
I do not find the item add symbol alert in the available menu items list.. I have been through the list 5 times but I dont see it..
can you provide me with a screenshot as to where the add symbol alert item is located in the list?
[2025-01-27 23:08:12]
John - SC Support - Posts: 39395
- Select "Global Settings >> Customize Chart Shortcut Menu".
- Make sure the topmost item on the left is selected (most likely this is "Delete and Download Data - All Charts".
- Press the 'a' key on your keyboard 3 times to get to the entry for "Add Symbol Alert".
- Make sure it is highlighted adn then move it to the right to add it to your context menu.
