Date/Time: Tue, 22 Apr 2025 07:11:36 +0000
Losing Configuration Settings On Update/Rollback
View Count: 808
[2025-01-27 05:27:54] |
User624595 - Posts: 243 |
Right click chart shortcut menu saved settings has been lost on version update/rollback. This did not occur in the past on update/rollback. Is this now expected? How can these be restored, and also retained through updates? |
[2025-01-27 07:10:31] |
Sierra_Chart Engineering - Posts: 19293 |
This is a problem when using more recent versions and going back to an older version. It is not the intention that this would happen but due to internal changes with menus that has occurred. You have to reconfigure the shortcut menus through Global Settings >> Customize * Menu. Reset the menu back to default and then add or remove the items you need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-27 07:11:18
