Date/Time: Tue, 22 Apr 2025 07:33:24 +0000
How to lower CPU load with Chart Replays
View Count: 160
[2025-01-26 17:28:18] |
User969241 - Posts: 133 |
I load 2 years of small range data and when I run replays for long periods of time for testing, it seems to really slow down and lag after a period of time. Is there a way to lessen this load?
[2025-01-26 21:09:16] |
Sierra_Chart Engineering - Posts: 19297 |
Refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Try loading less data in the chart. So a fewer number of days but the problem is as a chart replays, the number of days is going to increase. So that is not really a solution. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-26 21:09:56
[2025-01-26 23:20:18] |
User9415867 - Posts: 41 |
I need data from 2022-2023. Is there a way to only load that data and not include 2024?
[2025-01-26 23:24:08] |
Yes. With these Chart Settings: Chart Settings: Load Data Limiting Method: Date Range >> Date Range From / To (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Date Range menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-26 23:26:38
