Date/Time: Fri, 14 Mar 2025 12:27:46 +0000
Extending Volume Profile POC and Value Area low and High for Regular Hours
View Count: 247
[2025-01-26 02:37:00] |
User130696 - Posts: 104 |
Hello How do I extend the value area low, value area high and POC for Day Volume Profile till future interaction only in Regular Hours ? The lines as shown are cut off because it was intersected during the night session which I want to ignore and extend to regular session. In the attached screenshot, Please look above and left to the highlighted areas. |
[2025-01-26 07:42:29] |
Sierra_Chart Engineering - Posts: 18778 |
The only way to do this is to adjust the Session Times in the chart to only include the regular trading hours: Chart Session Times Also the screenshot attached is completely illegible. But it does not matter though. We understand what you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-26 07:50:28
[2025-01-26 08:54:14] |
ticinotrader - Posts: 407 |
@User130696 The screenshot is from a chartbook I created, which is available at Level 1 on my site. If you’re a member of my site, you can simply email me with any questions or post them on the member forum. |
[2025-01-27 21:27:56] |
Will not setting the session time to only day hours, remove the volume profile data from the night session also, I want all data points extended till future interaction during day prices.
[2025-01-28 15:51:36] |
John - SC Support - Posts: 38653 |
Yes, of course it will. The profiles are only based on the bars themselves. I want all data points extended till future interaction during day prices.
There is not a way to do this. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-29 23:53:26] |
So I cant overlay the VAL and VAH lines from a full session on to the Day Session and extend it ?
[2025-01-30 14:55:56] |
Yes, this would work. We thought you were referencing a different setup. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
