Date/Time: Tue, 22 Apr 2025 07:05:50 +0000
Historical bars not loading / volume not displaying
View Count: 161
[2025-01-25 22:38:55]
warpigs - Posts: 42
Hi. I've attached two images of the volume profile drawing. Currently, my intraday chart bars only load back to 7/21/24. These are 24 hour bars, not daily bars. The second image is with daily bars, they only load back to 7/23/24. I don't know why there is a two day difference. As you can see, it looks like the intraday volume data is not present on the 24 hour bar chart. The daily chart shows some aggregated volume. I am currently on my free trial.
imageMESH25-CME [CBV][M] 1 Day #1 2025-01-25 17_29_31.793.png / V - Attached On 2025-01-25 22:38:23 UTC - Size: 50.23 KB - 30 views
imageMESH25-CME [CBV][M] Daily #1 2025-01-25 17_32_48.009.png / V - Attached On 2025-01-25 22:38:27 UTC - Size: 52.11 KB - 32 views
[2025-01-25 23:06:52]
Sierra_Chart Engineering - Posts: 19293
For accurate volume profiles only use Intraday charts.
To load more data:
Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data
However, there are limitations on the amount of data you can load in a chart during a trial. This may be the reason.
Also refer to:
Chart Session Times: Creating Daily Bars with Custom Session Times
[2025-01-25 23:18:49]
warpigs - Posts: 42
Thanks. I have already read that page and taken the steps prescribed. My chart will not load past the dates in the pictures. Can you confirm that it is because I am on a free trial? Or is there another problem?
I am not seeing any information in the documentation that details how much data is included in the free trial, or how far back it goes. I see it listed at 186 days of aggregated data and 10 days of intra-day data, but that does not seem to be true.
Date Time Of Last Edit: 2025-01-25 23:27:32
[2025-01-26 21:41:02]
Yes Intraday charts are limited to 10 days on a trial:
Why you are getting more than 10 days is not known and we need to look into that.
