Date/Time: Tue, 22 Apr 2025 06:54:14 +0000
EUREX and CME Group
View Count: 196
[2025-01-25 14:07:34]
nicktrader - Posts: 748
For the CME Group you recommend Teton. What should the settings for the account be if I want to trade EUREX and CME Group at the same time?
Unfortunately, EUREX is not routed via Teton.
Many thanks
[2025-01-25 21:17:44]
Sierra_Chart Engineering - Posts: 19293
What we recommend doing is using two installations of Sierra Chart. One using Teton order routing for CME Group.
And another installation of Sierra Chart using CQG for EUREX.
Refer to:
Using Multiple Data and Trading Services at the Same Time
