Date/Time: Tue, 22 Apr 2025 07:27:50 +0000
fibo snaping line problem
View Count: 135
[2025-01-25 11:17:24] |
User395343 - Posts: 1 |
Hello, I have a new computer and I installed a new version of Sierra 2734 on it. However, I have a problem with fibo charts. The O% and 100% lines are not drawn to the tops and bottoms of the candles. What settings should I enable so that the lines are drawn and snaping to high and low automatically.
[2025-01-26 07:38:25] |
Sierra_Chart Engineering - Posts: 19295 |
Refer to: Chart Drawing Tools: Automatic Snapping of Chart Drawing Ends to Open, High, Low or Close Bar Values Chart Drawing Tools: Snapping (Global Settings >> Tool Settings >> General) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
