Date/Time: Wed, 27 Nov 2024 15:39:55 +0000
midpoint
View Count: 1557
[2014-09-17 21:14:49] |
navigator - Posts: 25 |
How do you draw a line that will be the developing midpoint of any day? Also is there a way to keep price a certain distance, right margin, from the price scale? |
[2014-09-18 05:38:44] |
1. For this we recommend using the Daily OHLC study. You are able to Graph the High and Low Historically with that study. There is also the HL (High Low) Average Study Subgraph which can be set to a visible Draw Style to give you the midpoint. Here is the documentation for the study: http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s137 2. See: http://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#ScrollingTheChart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-18 05:41:34
