Date/Time: Tue, 22 Apr 2025 10:17:26 +0000
Problem with Risk/Reward tool
View Count: 154
[2025-01-24 16:47:50]
User416156 - Posts: 10
For some reason, when I use the Risk/Reward tool in the Trading DOM, it always draws the R/R on the extreme left (see attached screenshot) which makes it difficult to see. Originally, I could click in the Trading DOM where I wanted the R/R tool to draw and it would place the drawing there instead of the extreme left.
Guess I've inadvertently changed something, but don't know what. Please advise how to correct.
Thanks.
imageSierraChartChartCalcOPNonLeft.png / V - Attached On 2025-01-24 16:47:14 UTC - Size: 106.74 KB - 34 views
[2025-01-24 17:00:52]
John - SC Support - Posts: 39395
The "Risk/Reward" tool is not meant to be used on a Trading DOM. The only tools that can be used properly on a Trading DOM are those that are found under "Chart >> Tools" on the Trading DOM itself.
If you ever had this working in a way that made some sense in the Trading DOM, then that was just luck at that time.
