Date/Time: Wed, 19 Mar 2025 02:31:35 +0000
Second Computer price freeze
View Count: 123
[2025-01-24 16:41:30] |
User257874 - Posts: 30 |
Hi, Teton, package 12, setup for two computers. When I'm using the second computer connected to the same Internet connection as the first computer, after 10 or 15 minutes. The second computer stop sending the feed even though SC is connected (in green) but I do not get the price moving as the first computer. Any ideas? again, the only difference today is that both computers are connected to the same Internet connection (IP) thanks Ralph |
[2025-01-24 16:57:16] |
John - SC Support - Posts: 38782 |
You should not have this issue. Please get us the Message Log for the computer that is having the issue, by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-24 17:02:40] |
2025-01-24 10:24:36.989 | Trade activity files set size: 34 2025-01-24 10:24:37.190 | Reading Internal Order ID file. 2025-01-24 10:24:37.193 | Reading Trade Orders file. 2025-01-24 10:24:37.199 | Reading Trade Positions file. 2025-01-24 10:24:37.206 | Reading Trade Account Data files. 2025-01-24 10:24:37.224 | Software version: 2732 64-bit 2025-01-24 10:24:37.224 | Primary Thread ID: 9224 2025-01-24 10:24:37.224 | Usage end date: 2025-06-14 2025-01-24 10:24:37.224 | Enabled for: Advanced Features 2. 2025-01-24 10:24:37.224 | Enabled for: Sierra Chart Historical Data Service. 2025-01-24 10:24:37.224 | Enabled for: Denali Real-Time Exchange Data Feed. 2025-01-24 10:24:37.224 | Enabled for: Delayed Denali Exchange Data Feed. 2025-01-24 10:24:37.224 | Enabled for exchange2: CME 2025-01-24 10:24:37.224 | Allow Support for Sierra Chart Data Feeds is enabled. 2025-01-24 10:24:37.224 | Current selected Data/Trading service: Teton CME Routing 2025-01-24 10:24:37.224 | Custom symbol settings values: enabled 2025-01-24 10:24:37.224 | Chart Update Interval: 400 2025-01-24 10:24:37.224 | Intraday Data Storage Time Unit: 0 2025-01-24 10:24:37.224 | Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) 2025-01-24 10:24:37.224 | 2025-01-24 15:24:37 Local computer time in UTC 2025-01-24 10:24:37.224 | 2025-01-24 10:24:37 Local computer time in SC Time Zone 2025-01-24 10:24:37.224 | Program path: C:\SierraChart2\ 2025-01-24 10:24:37.224 | Data Files path: C:\SierraChart2\Data\ 2025-01-24 10:24:37.224 | OS Version Number: 10.0 2025-01-24 10:24:37.224 | Locale Setting: C 2025-01-24 10:24:37.224 | DLLs: UserContributedStudies_64.dll 2025-01-24 10:24:37.224 | Allowed protected custom studies: 2025-01-24 10:24:37.224 | Crash reporter started: true 2025-01-24 10:24:37.224 | 2025-01-24 10:24:37.225 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. 2025-01-24 10:24:37.225 | Error getting address info for www.sierrachart.com. Windows error code 11001: No such host is known. * 2025-01-24 10:24:37.293 | Request for symbol settings MD5 finished unsuccessfully. Request ID: 1. Socket connection closed during the connection attempt. 2025-01-24 10:24:41.715 | 2025-01-24 10:24:41.715 | Teton CME Routing | Firm: AMP 2025-01-24 10:24:41.716 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:24:41.717 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:24:41.718 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:24:41.718 | Teton CME Routing | Failed connections: 1 2025-01-24 10:24:41.718 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:24:41.718 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:41.731 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:24:41.731 | Teton CME Routing | Disconnected. 2025-01-24 10:24:41.731 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:43.731 | 2025-01-24 10:24:43.731 | Teton CME Routing | Firm: AMP 2025-01-24 10:24:43.731 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:24:43.731 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:24:43.732 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:24:43.732 | Teton CME Routing | Failed connections: 2 2025-01-24 10:24:43.732 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:24:43.732 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:43.746 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:24:43.746 | Teton CME Routing | Disconnected. 2025-01-24 10:24:43.746 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:45.746 | 2025-01-24 10:24:45.746 | Teton CME Routing | Firm: AMP 2025-01-24 10:24:45.746 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:24:45.746 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:24:45.747 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:24:45.747 | Teton CME Routing | Failed connections: 3 2025-01-24 10:24:45.747 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:24:45.747 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:45.761 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:24:45.761 | Teton CME Routing | Disconnected. 2025-01-24 10:24:45.761 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:47.761 | 2025-01-24 10:24:47.761 | Teton CME Routing | Firm: AMP 2025-01-24 10:24:47.761 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:24:47.761 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:24:47.762 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:24:47.762 | Teton CME Routing | Failed connections: 4 2025-01-24 10:24:47.762 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:24:47.762 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:47.776 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:24:47.776 | Teton CME Routing | Disconnected. 2025-01-24 10:24:47.777 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:49.776 | 2025-01-24 10:24:49.776 | Teton CME Routing | Firm: AMP 2025-01-24 10:24:49.776 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:24:49.776 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:24:49.777 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:24:49.777 | Teton CME Routing | Failed connections: 5 2025-01-24 10:24:49.777 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:24:49.777 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:49.792 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:24:49.792 | Teton CME Routing | Disconnected. 2025-01-24 10:24:49.792 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:51.791 | 2025-01-24 10:24:51.791 | Teton CME Routing | Firm: AMP 2025-01-24 10:24:51.791 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:24:51.792 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:24:51.793 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:24:51.793 | Teton CME Routing | Failed connections: 6 2025-01-24 10:24:51.793 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:24:51.793 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:51.807 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:24:51.807 | Teton CME Routing | Disconnected. 2025-01-24 10:24:51.807 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:53.806 | 2025-01-24 10:24:53.806 | Teton CME Routing | Firm: AMP 2025-01-24 10:24:53.806 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:24:53.807 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:24:53.808 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:24:53.808 | Teton CME Routing | Failed connections: 7 2025-01-24 10:24:53.808 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:24:53.808 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:53.822 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:24:53.822 | Teton CME Routing | Disconnected. 2025-01-24 10:24:53.822 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:55.822 | 2025-01-24 10:24:55.822 | Teton CME Routing | Firm: AMP 2025-01-24 10:24:55.822 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:24:55.822 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:24:55.823 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:24:55.823 | Teton CME Routing | Failed connections: 8 2025-01-24 10:24:55.823 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:24:55.823 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:55.837 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:24:55.837 | Teton CME Routing | Disconnected. 2025-01-24 10:24:55.837 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:57.837 | 2025-01-24 10:24:57.837 | Teton CME Routing | Firm: AMP 2025-01-24 10:24:57.837 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:24:57.837 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:24:57.838 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:24:57.838 | Teton CME Routing | Failed connections: 9 2025-01-24 10:24:57.838 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:24:57.838 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:57.852 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:24:57.852 | Teton CME Routing | Disconnected. 2025-01-24 10:24:57.852 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:59.852 | 2025-01-24 10:24:59.852 | Teton CME Routing | Firm: AMP 2025-01-24 10:24:59.852 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:24:59.852 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:24:59.853 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:24:59.853 | Teton CME Routing | Failed connections: 10 2025-01-24 10:24:59.853 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:24:59.853 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:24:59.867 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:24:59.867 | Teton CME Routing | Disconnected. 2025-01-24 10:24:59.867 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:01.867 | 2025-01-24 10:25:01.867 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:01.867 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:25:01.867 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:01.868 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:01.868 | Teton CME Routing | Failed connections: 11 2025-01-24 10:25:01.868 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:01.868 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:01.883 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:01.883 | Teton CME Routing | Disconnected. 2025-01-24 10:25:01.883 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:03.882 | 2025-01-24 10:25:03.882 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:03.882 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:25:03.883 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:03.883 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:03.883 | Teton CME Routing | Failed connections: 12 2025-01-24 10:25:03.883 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:03.883 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:03.898 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:03.898 | Teton CME Routing | Disconnected. 2025-01-24 10:25:03.898 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:05.897 | 2025-01-24 10:25:05.897 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:05.898 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:25:05.898 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:05.900 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:05.901 | Teton CME Routing | Failed connections: 13 2025-01-24 10:25:05.901 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:05.901 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:05.913 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:05.913 | Teton CME Routing | Disconnected. 2025-01-24 10:25:05.913 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:07.913 | 2025-01-24 10:25:07.913 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:07.913 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:25:07.913 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:07.914 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:07.914 | Teton CME Routing | Failed connections: 14 2025-01-24 10:25:07.914 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:07.914 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:07.928 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:07.928 | Teton CME Routing | Disconnected. 2025-01-24 10:25:07.928 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:09.928 | 2025-01-24 10:25:09.928 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:09.928 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:25:09.928 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:09.929 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:09.929 | Teton CME Routing | Failed connections: 15 2025-01-24 10:25:09.929 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:09.929 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:09.943 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:09.943 | Teton CME Routing | Disconnected. 2025-01-24 10:25:09.943 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:11.943 | 2025-01-24 10:25:11.943 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:11.943 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:25:11.943 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:11.944 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:11.944 | Teton CME Routing | Failed connections: 16 2025-01-24 10:25:11.944 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:11.944 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:11.958 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:11.958 | Teton CME Routing | Disconnected. 2025-01-24 10:25:11.958 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:13.958 | 2025-01-24 10:25:13.958 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:13.958 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:25:13.958 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:13.959 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:13.959 | Teton CME Routing | Failed connections: 17 2025-01-24 10:25:13.959 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:13.959 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:13.974 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:13.974 | Teton CME Routing | Disconnected. 2025-01-24 10:25:13.974 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:15.973 | 2025-01-24 10:25:15.973 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:15.973 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:25:15.974 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:15.974 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:15.974 | Teton CME Routing | Failed connections: 18 2025-01-24 10:25:15.974 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:15.974 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:15.989 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:15.989 | Teton CME Routing | Disconnected. 2025-01-24 10:25:15.989 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:17.988 | 2025-01-24 10:25:17.988 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:17.988 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:25:17.989 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:17.990 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:17.990 | Teton CME Routing | Failed connections: 19 2025-01-24 10:25:17.990 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:17.990 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:18.004 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:18.004 | Teton CME Routing | Disconnected. 2025-01-24 10:25:18.004 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:20.003 | 2025-01-24 10:25:20.003 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:20.003 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:25:20.004 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:20.005 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:20.005 | Teton CME Routing | Failed connections: 20 2025-01-24 10:25:20.005 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:20.005 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:20.019 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:20.019 | Teton CME Routing | Disconnected. 2025-01-24 10:25:20.019 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:22.018 | 2025-01-24 10:25:22.019 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:22.019 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:25:22.019 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:22.020 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:22.020 | Teton CME Routing | Failed connections: 21 2025-01-24 10:25:22.020 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:22.020 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:22.034 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:22.034 | Teton CME Routing | Disconnected. 2025-01-24 10:25:22.034 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:24.034 | 2025-01-24 10:25:24.034 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:24.034 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:25:24.034 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:24.035 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:24.035 | Teton CME Routing | Failed connections: 22 2025-01-24 10:25:24.035 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:24.035 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:24.049 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:24.049 | Teton CME Routing | Disconnected. 2025-01-24 10:25:24.049 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:26.049 | 2025-01-24 10:25:26.049 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:26.049 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:25:26.049 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:26.050 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:26.050 | Teton CME Routing | Failed connections: 23 2025-01-24 10:25:26.050 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:26.050 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:26.064 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:26.064 | Teton CME Routing | Disconnected. 2025-01-24 10:25:26.065 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:28.064 | 2025-01-24 10:25:28.064 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:28.064 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:25:28.064 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:28.065 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:28.065 | Teton CME Routing | Failed connections: 24 2025-01-24 10:25:28.065 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:28.065 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:28.080 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:28.080 | Teton CME Routing | Disconnected. 2025-01-24 10:25:28.080 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:30.095 | 2025-01-24 10:25:30.095 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:30.095 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:25:30.095 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:30.096 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:30.096 | Teton CME Routing | Failed connections: 25 2025-01-24 10:25:30.096 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:30.096 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:30.110 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:30.110 | Teton CME Routing | Disconnected. 2025-01-24 10:25:30.110 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:32.110 | 2025-01-24 10:25:32.110 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:32.110 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:25:32.110 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:32.111 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:32.111 | Teton CME Routing | Failed connections: 26 2025-01-24 10:25:32.111 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:32.111 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:32.126 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:32.126 | Teton CME Routing | Disconnected. 2025-01-24 10:25:32.126 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:34.125 | 2025-01-24 10:25:34.125 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:34.125 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:25:34.126 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:34.126 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:34.126 | Teton CME Routing | Failed connections: 27 2025-01-24 10:25:34.126 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:34.126 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:34.141 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:34.141 | Teton CME Routing | Disconnected. 2025-01-24 10:25:34.141 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:36.140 | 2025-01-24 10:25:36.140 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:36.140 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:25:36.141 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:36.141 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:36.141 | Teton CME Routing | Failed connections: 28 2025-01-24 10:25:36.141 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:36.141 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:36.156 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:36.156 | Teton CME Routing | Disconnected. 2025-01-24 10:25:36.156 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:38.155 | 2025-01-24 10:25:38.155 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:38.155 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:25:38.156 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:38.157 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:38.157 | Teton CME Routing | Failed connections: 29 2025-01-24 10:25:38.157 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:38.157 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:38.171 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:38.171 | Teton CME Routing | Disconnected. 2025-01-24 10:25:38.171 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:40.170 | 2025-01-24 10:25:40.171 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:40.171 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:25:40.171 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:40.172 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:40.172 | Teton CME Routing | Failed connections: 30 2025-01-24 10:25:40.172 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:40.172 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:40.186 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:40.186 | Teton CME Routing | Disconnected. 2025-01-24 10:25:40.186 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:42.186 | 2025-01-24 10:25:42.186 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:42.186 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:25:42.186 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:42.187 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:42.187 | Teton CME Routing | Failed connections: 31 2025-01-24 10:25:42.187 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:42.187 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:42.201 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:42.201 | Teton CME Routing | Disconnected. 2025-01-24 10:25:42.201 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:44.201 | 2025-01-24 10:25:44.201 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:44.201 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:25:44.201 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:44.202 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:44.202 | Teton CME Routing | Failed connections: 32 2025-01-24 10:25:44.202 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:44.202 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:44.216 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:44.216 | Teton CME Routing | Disconnected. 2025-01-24 10:25:44.216 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:46.216 | 2025-01-24 10:25:46.216 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:46.216 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:25:46.217 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:46.217 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:46.217 | Teton CME Routing | Failed connections: 33 2025-01-24 10:25:46.217 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:46.217 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:46.232 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:46.232 | Teton CME Routing | Disconnected. 2025-01-24 10:25:46.232 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:48.231 | 2025-01-24 10:25:48.231 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:48.231 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:25:48.232 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:48.233 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:48.233 | Teton CME Routing | Failed connections: 34 2025-01-24 10:25:48.233 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:48.233 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:48.247 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:48.247 | Teton CME Routing | Disconnected. 2025-01-24 10:25:48.247 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:50.246 | 2025-01-24 10:25:50.246 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:50.246 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:25:50.247 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:50.248 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:50.248 | Teton CME Routing | Failed connections: 35 2025-01-24 10:25:50.248 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:50.248 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:50.262 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:50.262 | Teton CME Routing | Disconnected. 2025-01-24 10:25:50.262 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:52.261 | 2025-01-24 10:25:52.261 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:52.262 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:25:52.262 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:52.263 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:52.263 | Teton CME Routing | Failed connections: 36 2025-01-24 10:25:52.263 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:52.263 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:52.277 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:52.277 | Teton CME Routing | Disconnected. 2025-01-24 10:25:52.277 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:54.277 | 2025-01-24 10:25:54.277 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:54.277 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:25:54.277 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:54.278 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:54.278 | Teton CME Routing | Failed connections: 37 2025-01-24 10:25:54.278 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:54.278 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:54.292 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:54.292 | Teton CME Routing | Disconnected. 2025-01-24 10:25:54.292 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:56.292 | 2025-01-24 10:25:56.292 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:56.292 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:25:56.292 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:56.293 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:56.293 | Teton CME Routing | Failed connections: 38 2025-01-24 10:25:56.293 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:56.293 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:56.307 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:56.307 | Teton CME Routing | Disconnected. 2025-01-24 10:25:56.307 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:58.307 | 2025-01-24 10:25:58.307 | Teton CME Routing | Firm: AMP 2025-01-24 10:25:58.307 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:25:58.307 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:25:58.308 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:25:58.308 | Teton CME Routing | Failed connections: 39 2025-01-24 10:25:58.308 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:25:58.308 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:25:58.323 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:25:58.323 | Teton CME Routing | Disconnected. 2025-01-24 10:25:58.323 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:00.322 | 2025-01-24 10:26:00.322 | Teton CME Routing | Firm: AMP 2025-01-24 10:26:00.322 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:26:00.322 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:26:00.323 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:26:00.323 | Teton CME Routing | Failed connections: 40 2025-01-24 10:26:00.323 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:26:00.323 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:00.338 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:26:00.338 | Teton CME Routing | Disconnected. 2025-01-24 10:26:00.338 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:02.337 | 2025-01-24 10:26:02.337 | Teton CME Routing | Firm: AMP 2025-01-24 10:26:02.337 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:26:02.338 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:26:02.338 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:26:02.338 | Teton CME Routing | Failed connections: 41 2025-01-24 10:26:02.338 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:26:02.338 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:02.353 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:26:02.353 | Teton CME Routing | Disconnected. 2025-01-24 10:26:02.353 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:04.352 | 2025-01-24 10:26:04.352 | Teton CME Routing | Firm: AMP 2025-01-24 10:26:04.352 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:26:04.353 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:26:04.354 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:26:04.354 | Teton CME Routing | Failed connections: 42 2025-01-24 10:26:04.354 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:26:04.354 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:04.368 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:26:04.368 | Teton CME Routing | Disconnected. 2025-01-24 10:26:04.368 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:06.367 | 2025-01-24 10:26:06.368 | Teton CME Routing | Firm: AMP 2025-01-24 10:26:06.368 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:26:06.368 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:26:06.369 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:26:06.369 | Teton CME Routing | Failed connections: 43 2025-01-24 10:26:06.369 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:26:06.369 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:06.383 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:26:06.383 | Teton CME Routing | Disconnected. 2025-01-24 10:26:06.383 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:08.383 | 2025-01-24 10:26:08.383 | Teton CME Routing | Firm: AMP 2025-01-24 10:26:08.383 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:26:08.383 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:26:08.384 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:26:08.384 | Teton CME Routing | Failed connections: 44 2025-01-24 10:26:08.384 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:26:08.384 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:08.398 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:26:08.398 | Teton CME Routing | Disconnected. 2025-01-24 10:26:08.398 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:10.398 | 2025-01-24 10:26:10.398 | Teton CME Routing | Firm: AMP 2025-01-24 10:26:10.398 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:26:10.398 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:26:10.399 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:26:10.399 | Teton CME Routing | Failed connections: 45 2025-01-24 10:26:10.399 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:26:10.399 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:10.413 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:26:10.413 | Teton CME Routing | Disconnected. 2025-01-24 10:26:10.414 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:12.413 | 2025-01-24 10:26:12.413 | Teton CME Routing | Firm: AMP 2025-01-24 10:26:12.413 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:26:12.413 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:26:12.414 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:26:12.414 | Teton CME Routing | Failed connections: 46 2025-01-24 10:26:12.414 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:26:12.414 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:12.429 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:26:12.429 | Teton CME Routing | Disconnected. 2025-01-24 10:26:12.429 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:14.429 | 2025-01-24 10:26:14.429 | Teton CME Routing | Firm: AMP 2025-01-24 10:26:14.429 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:26:14.430 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:26:14.433 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:26:14.433 | Teton CME Routing | Failed connections: 47 2025-01-24 10:26:14.433 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:26:14.433 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:14.444 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:26:14.444 | Teton CME Routing | Disconnected. 2025-01-24 10:26:14.444 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:16.443 | 2025-01-24 10:26:16.443 | Teton CME Routing | Firm: AMP 2025-01-24 10:26:16.443 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:26:16.444 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:26:16.445 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:26:16.445 | Teton CME Routing | Failed connections: 48 2025-01-24 10:26:16.445 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:26:16.445 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:16.459 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:26:16.459 | Teton CME Routing | Disconnected. 2025-01-24 10:26:16.459 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:18.459 | 2025-01-24 10:26:18.459 | Teton CME Routing | Firm: AMP 2025-01-24 10:26:18.459 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:26:18.460 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:26:18.462 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:26:18.462 | Teton CME Routing | Failed connections: 49 2025-01-24 10:26:18.462 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:26:18.462 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:18.474 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:26:18.474 | Teton CME Routing | Disconnected. 2025-01-24 10:26:18.474 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:20.474 | 2025-01-24 10:26:20.474 | Teton CME Routing | Firm: AMP 2025-01-24 10:26:20.474 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:26:20.475 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:26:20.478 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:26:20.478 | Teton CME Routing | Failed connections: 50 2025-01-24 10:26:20.478 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:26:20.478 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:26:20.490 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:26:20.490 | Teton CME Routing | Disconnected. 2025-01-24 10:26:20.490 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:28:20.493 | 2025-01-24 10:28:20.493 | Teton CME Routing | Firm: AMP 2025-01-24 10:28:20.493 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:28:20.495 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:28:20.497 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:28:20.497 | Teton CME Routing | Failed connections: 51 2025-01-24 10:28:20.497 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:28:20.497 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:28:20.509 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:28:20.509 | Teton CME Routing | Disconnected. 2025-01-24 10:28:20.509 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:30:20.516 | 2025-01-24 10:30:20.516 | Teton CME Routing | Firm: AMP 2025-01-24 10:30:20.516 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:30:20.517 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:30:20.520 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:30:20.520 | Teton CME Routing | Failed connections: 52 2025-01-24 10:30:20.520 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:30:20.520 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:30:20.531 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:30:20.531 | Teton CME Routing | Disconnected. 2025-01-24 10:30:20.531 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:32:20.522 | 2025-01-24 10:32:20.522 | Teton CME Routing | Firm: AMP 2025-01-24 10:32:20.522 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:32:20.523 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:32:20.523 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:32:20.523 | Teton CME Routing | Failed connections: 53 2025-01-24 10:32:20.523 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:32:20.523 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:32:20.538 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:32:20.538 | Teton CME Routing | Disconnected. 2025-01-24 10:32:20.538 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:34:20.543 | 2025-01-24 10:34:20.543 | Teton CME Routing | Firm: AMP 2025-01-24 10:34:20.544 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:34:20.545 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:34:20.549 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:34:20.550 | Teton CME Routing | Failed connections: 54 2025-01-24 10:34:20.550 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:34:20.550 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:34:20.559 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:34:20.560 | Teton CME Routing | Disconnected. 2025-01-24 10:34:20.560 | Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:15.874 | File >> Disconnect selected. 2025-01-24 10:36:15.874 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:15.874 | Teton CME Routing | Disconnected. 2025-01-24 10:36:22.194 | 2025-01-24 10:36:22.194 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:22.194 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:36:22.194 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:22.195 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:22.195 | Teton CME Routing | Failed connections: 55 2025-01-24 10:36:22.195 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:22.195 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:22.202 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:22.202 | Teton CME Routing | Disconnected. 2025-01-24 10:36:22.202 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:24.202 | 2025-01-24 10:36:24.202 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:24.202 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:36:24.203 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:24.207 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:24.207 | Teton CME Routing | Failed connections: 56 2025-01-24 10:36:24.207 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:24.207 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:24.217 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:24.217 | Teton CME Routing | Disconnected. 2025-01-24 10:36:24.217 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:26.217 | 2025-01-24 10:36:26.218 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:26.218 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:36:26.219 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:26.222 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:26.222 | Teton CME Routing | Failed connections: 57 2025-01-24 10:36:26.222 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:26.222 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:26.233 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:26.233 | Teton CME Routing | Disconnected. 2025-01-24 10:36:26.233 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:28.232 | 2025-01-24 10:36:28.232 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:28.232 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:36:28.234 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:28.236 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:28.236 | Teton CME Routing | Failed connections: 58 2025-01-24 10:36:28.236 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:28.236 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:28.248 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:28.248 | Teton CME Routing | Disconnected. 2025-01-24 10:36:28.248 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:30.247 | 2025-01-24 10:36:30.248 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:30.248 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:36:30.249 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:30.251 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:30.251 | Teton CME Routing | Failed connections: 59 2025-01-24 10:36:30.251 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:30.251 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:30.263 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:30.263 | Teton CME Routing | Disconnected. 2025-01-24 10:36:30.263 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:32.263 | 2025-01-24 10:36:32.263 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:32.263 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:36:32.264 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:32.268 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:32.268 | Teton CME Routing | Failed connections: 60 2025-01-24 10:36:32.268 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:32.268 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:32.278 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:32.278 | Teton CME Routing | Disconnected. 2025-01-24 10:36:32.278 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:34.278 | 2025-01-24 10:36:34.278 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:34.278 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:36:34.279 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:34.282 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:34.283 | Teton CME Routing | Failed connections: 61 2025-01-24 10:36:34.283 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:34.283 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:34.293 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:34.293 | Teton CME Routing | Disconnected. 2025-01-24 10:36:34.293 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:36.293 | 2025-01-24 10:36:36.293 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:36.293 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:36:36.294 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:36.297 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:36.297 | Teton CME Routing | Failed connections: 62 2025-01-24 10:36:36.297 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:36.297 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:36.308 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:36.309 | Teton CME Routing | Disconnected. 2025-01-24 10:36:36.309 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:38.308 | 2025-01-24 10:36:38.308 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:38.308 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:36:38.309 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:38.312 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:38.312 | Teton CME Routing | Failed connections: 63 2025-01-24 10:36:38.312 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:38.312 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:38.324 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:38.324 | Teton CME Routing | Disconnected. 2025-01-24 10:36:38.324 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:40.323 | 2025-01-24 10:36:40.323 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:40.323 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:36:40.324 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:40.327 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:40.328 | Teton CME Routing | Failed connections: 64 2025-01-24 10:36:40.328 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:40.328 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:40.339 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:40.339 | Teton CME Routing | Disconnected. 2025-01-24 10:36:40.339 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:42.338 | 2025-01-24 10:36:42.339 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:42.339 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:36:42.340 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:42.343 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:42.343 | Teton CME Routing | Failed connections: 65 2025-01-24 10:36:42.343 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:42.343 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:42.354 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:42.354 | Teton CME Routing | Disconnected. 2025-01-24 10:36:42.354 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:44.353 | 2025-01-24 10:36:44.354 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:44.354 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:36:44.355 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:44.357 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:44.358 | Teton CME Routing | Failed connections: 66 2025-01-24 10:36:44.358 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:44.358 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:44.369 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:44.369 | Teton CME Routing | Disconnected. 2025-01-24 10:36:44.369 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:46.369 | 2025-01-24 10:36:46.369 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:46.369 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:36:46.370 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:46.372 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:46.372 | Teton CME Routing | Failed connections: 67 2025-01-24 10:36:46.372 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:46.372 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:46.384 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:46.384 | Teton CME Routing | Disconnected. 2025-01-24 10:36:46.384 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:48.384 | 2025-01-24 10:36:48.384 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:48.384 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:36:48.385 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:48.388 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:48.388 | Teton CME Routing | Failed connections: 68 2025-01-24 10:36:48.388 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:48.388 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:48.399 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:48.399 | Teton CME Routing | Disconnected. 2025-01-24 10:36:48.399 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:50.399 | 2025-01-24 10:36:50.399 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:50.399 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:36:50.400 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:50.403 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:50.403 | Teton CME Routing | Failed connections: 69 2025-01-24 10:36:50.403 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:50.403 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:50.415 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:50.415 | Teton CME Routing | Disconnected. 2025-01-24 10:36:50.415 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:52.414 | 2025-01-24 10:36:52.414 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:52.414 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:36:52.415 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:52.418 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:52.418 | Teton CME Routing | Failed connections: 70 2025-01-24 10:36:52.418 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:52.418 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:52.430 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:52.430 | Teton CME Routing | Disconnected. 2025-01-24 10:36:52.430 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:54.429 | 2025-01-24 10:36:54.430 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:54.430 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:36:54.431 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:54.433 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:54.433 | Teton CME Routing | Failed connections: 71 2025-01-24 10:36:54.433 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:54.433 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:54.445 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:54.445 | Teton CME Routing | Disconnected. 2025-01-24 10:36:54.445 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:56.444 | 2025-01-24 10:36:56.445 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:56.445 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:36:56.446 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:56.448 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:56.449 | Teton CME Routing | Failed connections: 72 2025-01-24 10:36:56.449 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:56.449 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:56.460 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:56.460 | Teton CME Routing | Disconnected. 2025-01-24 10:36:56.460 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:58.460 | 2025-01-24 10:36:58.460 | Teton CME Routing | Firm: AMP 2025-01-24 10:36:58.460 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:36:58.461 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:36:58.464 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:36:58.464 | Teton CME Routing | Failed connections: 73 2025-01-24 10:36:58.464 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:36:58.464 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:36:58.475 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:36:58.475 | Teton CME Routing | Disconnected. 2025-01-24 10:36:58.475 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:37:00.475 | 2025-01-24 10:37:00.475 | Teton CME Routing | Firm: AMP 2025-01-24 10:37:00.475 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:37:00.476 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:37:00.478 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:37:00.479 | Teton CME Routing | Failed connections: 74 2025-01-24 10:37:00.479 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:37:00.479 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:37:00.490 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:37:00.490 | Teton CME Routing | Disconnected. 2025-01-24 10:37:00.490 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:37:02.490 | 2025-01-24 10:37:02.490 | Teton CME Routing | Firm: AMP 2025-01-24 10:37:02.490 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:37:02.491 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:37:02.494 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:37:02.494 | Teton CME Routing | Failed connections: 75 2025-01-24 10:37:02.494 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:37:02.494 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:37:02.505 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:37:02.505 | Teton CME Routing | Disconnected. 2025-01-24 10:37:02.505 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:37:04.505 | 2025-01-24 10:37:04.506 | Teton CME Routing | Firm: AMP 2025-01-24 10:37:04.506 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:37:04.507 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:37:04.511 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:37:04.511 | Teton CME Routing | Failed connections: 76 2025-01-24 10:37:04.511 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:37:04.511 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:37:04.526 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:37:04.526 | Teton CME Routing | Disconnected. 2025-01-24 10:37:04.526 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:37:06.520 | 2025-01-24 10:37:06.520 | Teton CME Routing | Firm: AMP 2025-01-24 10:37:06.520 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:37:06.521 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:37:06.524 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:37:06.525 | Teton CME Routing | Failed connections: 77 2025-01-24 10:37:06.525 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:37:06.525 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:37:06.536 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:37:06.536 | Teton CME Routing | Disconnected. 2025-01-24 10:37:06.536 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:37:08.535 | 2025-01-24 10:37:08.536 | Teton CME Routing | Firm: AMP 2025-01-24 10:37:08.536 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:37:08.537 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:37:08.540 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:37:08.540 | Teton CME Routing | Failed connections: 78 2025-01-24 10:37:08.540 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:37:08.540 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:37:08.552 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:37:08.552 | Teton CME Routing | Disconnected. 2025-01-24 10:37:08.552 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:37:10.551 | 2025-01-24 10:37:10.551 | Teton CME Routing | Firm: AMP 2025-01-24 10:37:10.551 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:37:10.552 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:37:10.555 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:37:10.555 | Teton CME Routing | Failed connections: 79 2025-01-24 10:37:10.555 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:37:10.555 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:37:10.566 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:37:10.566 | Teton CME Routing | Disconnected. 2025-01-24 10:37:10.566 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:37:10.954 | File >> Disconnect selected. 2025-01-24 10:37:10.954 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:37:10.954 | Teton CME Routing | Disconnected. 2025-01-24 10:37:57.610 | 2025-01-24 10:37:57.610 | Teton CME Routing | Firm: AMP 2025-01-24 10:37:57.610 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:37:57.610 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:37:57.612 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:37:57.612 | Teton CME Routing | Failed connections: 80 2025-01-24 10:37:57.612 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:37:57.612 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:37:57.618 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:37:57.618 | Teton CME Routing | Disconnected. 2025-01-24 10:37:57.618 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:37:59.618 | 2025-01-24 10:37:59.618 | Teton CME Routing | Firm: AMP 2025-01-24 10:37:59.618 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:37:59.619 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:37:59.622 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:37:59.622 | Teton CME Routing | Failed connections: 81 2025-01-24 10:37:59.622 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:37:59.622 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:37:59.633 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:37:59.634 | Teton CME Routing | Disconnected. 2025-01-24 10:37:59.634 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:01.633 | 2025-01-24 10:38:01.633 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:01.633 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:38:01.636 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:01.636 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:01.637 | Teton CME Routing | Failed connections: 82 2025-01-24 10:38:01.637 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:01.637 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:01.649 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:01.649 | Teton CME Routing | Disconnected. 2025-01-24 10:38:01.649 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:03.648 | 2025-01-24 10:38:03.648 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:03.648 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:38:03.649 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:03.652 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:03.652 | Teton CME Routing | Failed connections: 83 2025-01-24 10:38:03.652 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:03.652 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:03.664 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:03.664 | Teton CME Routing | Disconnected. 2025-01-24 10:38:03.664 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:05.663 | 2025-01-24 10:38:05.663 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:05.663 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:38:05.664 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:05.667 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:05.667 | Teton CME Routing | Failed connections: 84 2025-01-24 10:38:05.667 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:05.667 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:05.679 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:05.679 | Teton CME Routing | Disconnected. 2025-01-24 10:38:05.679 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:07.678 | 2025-01-24 10:38:07.678 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:07.678 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:38:07.679 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:07.682 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:07.682 | Teton CME Routing | Failed connections: 85 2025-01-24 10:38:07.682 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:07.682 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:07.694 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:07.694 | Teton CME Routing | Disconnected. 2025-01-24 10:38:07.694 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:09.693 | 2025-01-24 10:38:09.694 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:09.694 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:38:09.695 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:09.698 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:09.698 | Teton CME Routing | Failed connections: 86 2025-01-24 10:38:09.698 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:09.698 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:09.709 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:09.709 | Teton CME Routing | Disconnected. 2025-01-24 10:38:09.709 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:11.709 | 2025-01-24 10:38:11.709 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:11.709 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:38:11.710 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:11.713 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:11.713 | Teton CME Routing | Failed connections: 87 2025-01-24 10:38:11.713 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:11.713 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:11.724 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:11.725 | Teton CME Routing | Disconnected. 2025-01-24 10:38:11.725 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:13.724 | 2025-01-24 10:38:13.724 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:13.724 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:38:13.725 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:13.729 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:13.729 | Teton CME Routing | Failed connections: 88 2025-01-24 10:38:13.729 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:13.729 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:13.740 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:13.740 | Teton CME Routing | Disconnected. 2025-01-24 10:38:13.740 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:15.739 | 2025-01-24 10:38:15.739 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:15.739 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:38:15.740 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:15.743 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:15.743 | Teton CME Routing | Failed connections: 89 2025-01-24 10:38:15.743 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:15.743 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:15.755 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:15.755 | Teton CME Routing | Disconnected. 2025-01-24 10:38:15.755 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:17.754 | 2025-01-24 10:38:17.754 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:17.754 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:38:17.755 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:17.759 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:17.759 | Teton CME Routing | Failed connections: 90 2025-01-24 10:38:17.759 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:17.759 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:17.770 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:17.770 | Teton CME Routing | Disconnected. 2025-01-24 10:38:17.770 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:19.769 | 2025-01-24 10:38:19.769 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:19.769 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:38:19.770 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:19.773 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:19.773 | Teton CME Routing | Failed connections: 91 2025-01-24 10:38:19.773 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:19.773 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:19.785 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:19.785 | Teton CME Routing | Disconnected. 2025-01-24 10:38:19.785 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:21.784 | 2025-01-24 10:38:21.784 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:21.784 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:38:21.785 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:21.789 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:21.789 | Teton CME Routing | Failed connections: 92 2025-01-24 10:38:21.789 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:21.789 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:21.800 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:21.800 | Teton CME Routing | Disconnected. 2025-01-24 10:38:21.800 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:23.799 | 2025-01-24 10:38:23.800 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:23.800 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:38:23.801 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:23.804 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:23.804 | Teton CME Routing | Failed connections: 93 2025-01-24 10:38:23.804 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:23.804 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:23.815 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:23.815 | Teton CME Routing | Disconnected. 2025-01-24 10:38:23.815 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:25.815 | 2025-01-24 10:38:25.815 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:25.815 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:38:25.816 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:25.819 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:25.819 | Teton CME Routing | Failed connections: 94 2025-01-24 10:38:25.819 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:25.819 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:25.830 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:25.830 | Teton CME Routing | Disconnected. 2025-01-24 10:38:25.830 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:27.830 | 2025-01-24 10:38:27.830 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:27.830 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:38:27.844 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:27.844 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:27.844 | Teton CME Routing | Failed connections: 95 2025-01-24 10:38:27.844 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:27.844 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:27.845 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:27.845 | Teton CME Routing | Disconnected. 2025-01-24 10:38:27.846 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:29.860 | 2025-01-24 10:38:29.860 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:29.860 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:38:29.861 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:29.864 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:29.864 | Teton CME Routing | Failed connections: 96 2025-01-24 10:38:29.864 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:29.864 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:29.876 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:29.876 | Teton CME Routing | Disconnected. 2025-01-24 10:38:29.876 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:31.876 | 2025-01-24 10:38:31.876 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:31.876 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:38:31.877 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:31.880 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:31.880 | Teton CME Routing | Failed connections: 97 2025-01-24 10:38:31.880 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:31.880 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:31.891 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:31.891 | Teton CME Routing | Disconnected. 2025-01-24 10:38:31.891 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:33.891 | 2025-01-24 10:38:33.891 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:33.891 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:38:33.892 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:33.895 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:33.895 | Teton CME Routing | Failed connections: 98 2025-01-24 10:38:33.895 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:33.895 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:33.907 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:33.907 | Teton CME Routing | Disconnected. 2025-01-24 10:38:33.907 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:35.906 | 2025-01-24 10:38:35.906 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:35.906 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:38:35.907 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:35.910 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:35.910 | Teton CME Routing | Failed connections: 99 2025-01-24 10:38:35.910 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:35.910 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:35.922 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:35.922 | Teton CME Routing | Disconnected. 2025-01-24 10:38:35.922 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:37.921 | 2025-01-24 10:38:37.921 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:37.921 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:38:37.922 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:37.925 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:37.926 | Teton CME Routing | Failed connections: 100 2025-01-24 10:38:37.926 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:37.926 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:37.937 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:37.937 | Teton CME Routing | Disconnected. 2025-01-24 10:38:37.937 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:39.936 | 2025-01-24 10:38:39.936 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:39.936 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:38:39.937 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:39.941 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:39.941 | Teton CME Routing | Failed connections: 101 2025-01-24 10:38:39.941 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:39.941 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:39.952 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:39.952 | Teton CME Routing | Disconnected. 2025-01-24 10:38:39.952 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:41.952 | 2025-01-24 10:38:41.952 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:41.952 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:38:41.953 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:41.956 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:41.956 | Teton CME Routing | Failed connections: 102 2025-01-24 10:38:41.956 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:41.956 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:41.967 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:41.967 | Teton CME Routing | Disconnected. 2025-01-24 10:38:41.967 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:43.967 | 2025-01-24 10:38:43.967 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:43.967 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:38:43.968 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:43.971 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:43.971 | Teton CME Routing | Failed connections: 103 2025-01-24 10:38:43.971 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:43.971 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:43.984 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:43.984 | Teton CME Routing | Disconnected. 2025-01-24 10:38:43.984 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:45.982 | 2025-01-24 10:38:45.983 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:45.983 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:38:45.984 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:45.987 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:45.988 | Teton CME Routing | Failed connections: 104 2025-01-24 10:38:45.988 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:45.988 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:45.998 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:45.998 | Teton CME Routing | Disconnected. 2025-01-24 10:38:45.998 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:47.997 | 2025-01-24 10:38:47.997 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:47.997 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:38:47.998 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:48.001 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:48.002 | Teton CME Routing | Failed connections: 105 2025-01-24 10:38:48.002 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:48.002 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:48.013 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:48.013 | Teton CME Routing | Disconnected. 2025-01-24 10:38:48.013 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:50.012 | 2025-01-24 10:38:50.013 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:50.013 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:38:50.014 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:50.017 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:50.017 | Teton CME Routing | Failed connections: 106 2025-01-24 10:38:50.017 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:50.017 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:50.028 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:50.028 | Teton CME Routing | Disconnected. 2025-01-24 10:38:50.028 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:52.028 | 2025-01-24 10:38:52.028 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:52.028 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:38:52.029 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:52.032 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:52.032 | Teton CME Routing | Failed connections: 107 2025-01-24 10:38:52.032 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:52.032 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:52.043 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:52.043 | Teton CME Routing | Disconnected. 2025-01-24 10:38:52.043 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:54.043 | 2025-01-24 10:38:54.043 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:54.043 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:38:54.044 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:54.047 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:54.047 | Teton CME Routing | Failed connections: 108 2025-01-24 10:38:54.047 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:54.047 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:54.058 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:54.058 | Teton CME Routing | Disconnected. 2025-01-24 10:38:54.058 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:56.058 | 2025-01-24 10:38:56.058 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:56.058 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:38:56.059 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:56.062 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:56.062 | Teton CME Routing | Failed connections: 109 2025-01-24 10:38:56.063 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:56.063 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:56.073 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:56.073 | Teton CME Routing | Disconnected. 2025-01-24 10:38:56.073 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:56.557 | The message log has been sent to support. * 2025-01-24 10:38:56.558 | Error getting address info for www.sierrachart.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:56.592 | HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | CloseSocket call. 2025-01-24 10:38:56.592 | There was an error sending the Message Log. Socket connection closed during the connection attempt. * 2025-01-24 10:38:58.073 | 2025-01-24 10:38:58.073 | Teton CME Routing | Firm: AMP 2025-01-24 10:38:58.073 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:38:58.075 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:38:58.078 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:38:58.078 | Teton CME Routing | Failed connections: 110 2025-01-24 10:38:58.078 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:38:58.078 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:38:58.089 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:38:58.089 | Teton CME Routing | Disconnected. 2025-01-24 10:38:58.089 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:00.089 | 2025-01-24 10:39:00.089 | Teton CME Routing | Firm: AMP 2025-01-24 10:39:00.089 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:39:00.090 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:39:00.093 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:39:00.093 | Teton CME Routing | Failed connections: 111 2025-01-24 10:39:00.093 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:39:00.093 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:00.104 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:39:00.104 | Teton CME Routing | Disconnected. 2025-01-24 10:39:00.104 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:02.105 | 2025-01-24 10:39:02.105 | Teton CME Routing | Firm: AMP 2025-01-24 10:39:02.105 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:39:02.106 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:39:02.109 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:39:02.109 | Teton CME Routing | Failed connections: 112 2025-01-24 10:39:02.109 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:39:02.109 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:02.120 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:39:02.120 | Teton CME Routing | Disconnected. 2025-01-24 10:39:02.120 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:04.120 | 2025-01-24 10:39:04.120 | Teton CME Routing | Firm: AMP 2025-01-24 10:39:04.120 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:39:04.121 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:39:04.124 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:39:04.124 | Teton CME Routing | Failed connections: 113 2025-01-24 10:39:04.124 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:39:04.124 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:04.136 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:39:04.137 | Teton CME Routing | Disconnected. 2025-01-24 10:39:04.137 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:06.135 | 2025-01-24 10:39:06.135 | Teton CME Routing | Firm: AMP 2025-01-24 10:39:06.135 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:39:06.136 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:39:06.139 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:39:06.140 | Teton CME Routing | Failed connections: 114 2025-01-24 10:39:06.140 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:39:06.140 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:06.151 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:39:06.151 | Teton CME Routing | Disconnected. 2025-01-24 10:39:06.151 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:08.150 | 2025-01-24 10:39:08.150 | Teton CME Routing | Firm: AMP 2025-01-24 10:39:08.150 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:39:08.151 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:39:08.154 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:39:08.154 | Teton CME Routing | Failed connections: 115 2025-01-24 10:39:08.154 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:39:08.154 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:08.166 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:39:08.166 | Teton CME Routing | Disconnected. 2025-01-24 10:39:08.166 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:10.165 | 2025-01-24 10:39:10.166 | Teton CME Routing | Firm: AMP 2025-01-24 10:39:10.166 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:39:10.167 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:39:10.169 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:39:10.170 | Teton CME Routing | Failed connections: 116 2025-01-24 10:39:10.170 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:39:10.170 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:10.181 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:39:10.181 | Teton CME Routing | Disconnected. 2025-01-24 10:39:10.181 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:12.181 | 2025-01-24 10:39:12.181 | Teton CME Routing | Firm: AMP 2025-01-24 10:39:12.181 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:39:12.182 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:39:12.184 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:39:12.184 | Teton CME Routing | Failed connections: 117 2025-01-24 10:39:12.184 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:39:12.184 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:12.197 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:39:12.197 | Teton CME Routing | Disconnected. 2025-01-24 10:39:12.197 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:14.204 | 2025-01-24 10:39:14.205 | Teton CME Routing | Firm: AMP 2025-01-24 10:39:14.205 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:39:14.208 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:39:14.209 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:39:14.209 | Teton CME Routing | Failed connections: 118 2025-01-24 10:39:14.209 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:39:14.209 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:14.237 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:39:14.238 | Teton CME Routing | Disconnected. 2025-01-24 10:39:14.238 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:16.249 | 2025-01-24 10:39:16.249 | Teton CME Routing | Firm: AMP 2025-01-24 10:39:16.249 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:39:16.251 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:39:16.257 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:39:16.257 | Teton CME Routing | Failed connections: 119 2025-01-24 10:39:16.257 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:39:16.257 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:16.289 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:39:16.290 | Teton CME Routing | Disconnected. 2025-01-24 10:39:16.290 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:18.295 | 2025-01-24 10:39:18.296 | Teton CME Routing | Firm: AMP 2025-01-24 10:39:18.296 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:39:18.296 | Error getting address info for futurestrading17.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:39:18.299 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:39:18.299 | Teton CME Routing | Failed connections: 120 2025-01-24 10:39:18.299 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:39:18.299 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:18.322 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:39:18.322 | Teton CME Routing | Disconnected. 2025-01-24 10:39:18.322 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:20.325 | 2025-01-24 10:39:20.326 | Teton CME Routing | Firm: AMP 2025-01-24 10:39:20.326 | Teton CME Routing | Connecting to the server futurestrading19.sierracharts.com. Port 11066 2025-01-24 10:39:20.327 | Error getting address info for futurestrading19.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:39:20.330 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:39:20.330 | Teton CME Routing | Failed connections: 121 2025-01-24 10:39:20.330 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:39:20.330 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:20.341 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:39:20.341 | Teton CME Routing | Disconnected. 2025-01-24 10:39:20.341 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:22.342 | 2025-01-24 10:39:22.343 | Teton CME Routing | Firm: AMP 2025-01-24 10:39:22.343 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:39:22.343 | Error getting address info for futurestrading14.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:39:22.347 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:39:22.347 | Teton CME Routing | Failed connections: 122 2025-01-24 10:39:22.347 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:39:22.347 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:22.358 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:39:22.358 | Teton CME Routing | Disconnected. 2025-01-24 10:39:22.358 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:24.358 | 2025-01-24 10:39:24.358 | Teton CME Routing | Firm: AMP 2025-01-24 10:39:24.358 | Teton CME Routing | Connecting to the server futurestrading15.sierracharts.com. Port 11067 2025-01-24 10:39:24.359 | Error getting address info for futurestrading15.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:39:24.362 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:39:24.362 | Teton CME Routing | Failed connections: 123 2025-01-24 10:39:24.362 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:39:24.362 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:24.373 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:39:24.373 | Teton CME Routing | Disconnected. 2025-01-24 10:39:24.373 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:26.373 | 2025-01-24 10:39:26.373 | Teton CME Routing | Firm: AMP 2025-01-24 10:39:26.374 | Teton CME Routing | Connecting to the server futurestrading16.sierracharts.com. Port 11066 2025-01-24 10:39:26.375 | Error getting address info for futurestrading16.sierracharts.com. Windows error code 11001: No such host is known. * 2025-01-24 10:39:26.378 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:39:26.378 | Teton CME Routing | Failed connections: 124 2025-01-24 10:39:26.378 | Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. 2025-01-24 10:39:26.378 | Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:26.388 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:39:26.388 | Teton CME Routing | Disconnected. 2025-01-24 10:39:26.388 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:39:28.383 | 2025-01-24 10:39:28.383 | Teton CME Routing | Firm: AMP 2025-01-24 10:39:28.383 | Teton CME Routing | Connecting to the server futurestrading17.sierracharts.com. Port 11066 2025-01-24 10:39:28.410 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2025-01-24 10:39:28.410 | DTC Client socket (1) | New receive buffer size: 0 2025-01-24 10:39:28.410 | DTC Client socket (1) | Connecting to IP: 38.142.127.146. 2025-01-24 10:39:28.448 | Teton CME Routing | Network connection to server complete. 2025-01-24 10:39:28.448 | Teton CME Routing | Starting socket receive thread. 2025-01-24 10:39:28.448 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2025-01-24 10:39:28.570 | Teton CME Routing | Setting DTC encoding to Binary VLS 2025-01-24 10:39:28.570 | Teton CME Routing | Sending logon request message. 2025-01-24 10:39:28.669 | Teton CME Routing | Received logon response. 2025-01-24 10:39:28.669 | Teton CME Routing | Server Name: SC DTC Server. Build=51672. 2025-01-24 10:39:28.669 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2025-01-24 10:39:28.669 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2025-01-24 10:39:28.669 | Teton CME Routing | Trading is supported. 2025-01-24 10:39:28.669 | Teton CME Routing | Order cancel and replace is supported. 2025-01-24 10:39:28.669 | Teton CME Routing | OCO Orders supported. 2025-01-24 10:39:28.669 | Teton CME Routing | Bracket Orders supported. 2025-01-24 10:39:28.669 | Teton CME Routing | MarketDepthIsSupported: 1 2025-01-24 10:39:28.669 | Teton CME Routing | Connected to server complete. 2025-01-24 10:39:28.671 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-01-24 10:39:28.672 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2025-01-24 10:39:28.679 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2025-01-24 14:59:55.584011 2025-01-24 10:39:28.711 | Updated verified funded futures trading account ending date to: 2025-02-23 15:39:28 2025-01-24 10:39:28.786 | Teton CME Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=166331 2025-01-24 10:39:28.856 | Teton CME Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=166331A 2025-01-24 10:39:48.717 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2025-01-24 10:39:48.958 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2025-02-23"}. Success=true 2025-01-24 10:39:57.366 | MESH25_FUT_CME 5 Min #1 | Reloading chart. 2025-01-24 10:39:57.377 | MESH25_FUT_CME 1 Min #2 | Reloading chart. 2025-01-24 10:39:57.761 | Mapping MESH25_FUT_CME to MESH25. Service code: cme 2025-01-24 10:39:57.761 | Using symbol data fast lookup vector 2025-01-24 10:39:57.761 | Denali Data Feed | Starting real-time market data updates for: MESH25_FUT_CME (MESH25). ID: 1 Service code: cme 2025-01-24 10:39:57.762 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048 2025-01-24 10:39:57.762 | Denali Data Feed | Requesting security definition data for: MESH25_FUT_CME (MESH25). ID: 1 2025-01-24 10:39:57.762 | Starting DelayedDownloadMonitoringTimer 2025-01-24 10:39:57.762 | Starting HDTimeoutTimer 2025-01-24 10:39:57.762 | Added historical Intraday data request for MESH25_FUT_CME to the queue. 2025-01-24 10:39:57.762 | Intraday data recording state for symbol MESH25_FUT_CME is set to download 'Pending'. 2025-01-24 10:39:57.763 | Triggering next historical data download in queue. 2025-01-24 10:39:57.764 | Delaying start of download for MESH25_FUT_CME. 2025-01-24 10:39:57.783 | DTC Client socket (2) | Creating socket. 2025-01-24 10:39:57.783 | DTC Client socket (2) | New receive buffer size: 0 2025-01-24 10:39:57.783 | DTC Client socket (2) | Connecting to IP: 67.214.125.6. 2025-01-24 10:39:57.797 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESH25_FUT_CME 2025-01-24 10:39:57.797 | Teton CME Routing | Setting external service identifier for symbol MESH25_FUT_CME to 42005347 2025-01-24 10:39:57.797 | Teton CME Routing | Received security definition for symbol MESH25_FUT_CME 2025-01-24 10:39:57.821 | Denali Data Feed | Network connection to server complete. 2025-01-24 10:39:57.821 | Denali Data Feed | Starting socket receive thread. 2025-01-24 10:39:57.821 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-01-24 10:39:57.883 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-01-24 10:39:57.883 | Denali Data Feed | Sending logon request message. 2025-01-24 10:39:57.934 | Denali Data Feed | Received logon response. 2025-01-24 10:39:57.934 | Denali Data Feed | Server Name: RealTimeServer. 2025-01-24 10:39:57.934 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-01-24 10:39:57.934 | Denali Data Feed | Logon error received from server: Maximum connections reached. 2025-01-24 10:39:57.934 | Denali Data Feed | Failed connections: 1 2025-01-24 10:39:57.934 | Denali Data Feed | Waiting for socket receive thread to end 2025-01-24 10:39:57.934 | DTC Client socket (2) | CloseSocket call. 2025-01-24 10:39:57.934 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2025-01-24 10:39:57.934 | Denali Data Feed | Disconnected from the server. 2025-01-24 10:39:57.934 | Denali Data Feed | Data feed disconnected. Will reconnect in 3 seconds. 2025-01-24 10:39:57.972 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-01-24 10:39:57.972 | DTC Client socket (2) | Closed. 2025-01-24 10:39:58.667 | Requesting market depth updates for: MESH25_FUT_CME if supported. NumLevels=100 2025-01-24 10:39:59.938 | MESH25_FUT_CME[M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-24 10:39:59.950 | MESH25_FUT_CME[M] 5 Min #1 | Chart data loading complete. 2025-01-24 10:40:00.590 | MESH25_FUT_CME[M] 1 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-24 10:40:00.591 | MESH25_FUT_CME[M] 1 Min #2 | Chart data loading complete. 2025-01-24 10:40:00.932 | Denali Data Feed | Connecting to the server ds26.sierracharts.com. Port 443 2025-01-24 10:40:00.966 | DTC Client socket (2) | Creating socket. 2025-01-24 10:40:00.966 | DTC Client socket (2) | New receive buffer size: 0 2025-01-24 10:40:00.966 | DTC Client socket (2) | Connecting to IP: 64.152.155.17. 2025-01-24 10:40:01.003 | Denali Data Feed | Network connection to server complete. 2025-01-24 10:40:01.003 | Denali Data Feed | Starting socket receive thread. 2025-01-24 10:40:01.003 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-01-24 10:40:01.046 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-01-24 10:40:01.046 | Denali Data Feed | Sending logon request message. 2025-01-24 10:40:01.546 | Denali Data Feed | Received logon response. 2025-01-24 10:40:01.546 | Denali Data Feed | Server Name: SC Realtime Server. 2025-01-24 10:40:01.546 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-01-24 10:40:01.546 | Denali Data Feed | Successfully connected. 2025-01-24 10:40:01.546 | Denali Data Feed | Trading is not supported. 2025-01-24 10:40:01.546 | Denali Data Feed | MarketDepthIsSupported: 1 2025-01-24 10:40:01.546 | Denali Data Feed | Restarting real-time data updates for symbol: MESH25_FUT_CME -> MESH25. Market Depth data restarted. 2025-01-24 10:40:01.673 | Denali Data Feed | Clearing market depth for MESH25_FUT_CME 2025-01-24 10:40:01.674 | Denali Data Feed | Setting external service identifier for symbol MESH25_FUT_CME to 42005347 2025-01-24 10:40:01.674 | Denali Data Feed | Received security definition for symbol MESH25_FUT_CME 2025-01-24 10:40:06.759 | HD Request # 1 | Downloading Intraday chart data for MESH25_FUT_CME to the file MESH25_FUT_CME.scid. Service: cme 2025-01-24 10:40:06.761 | HD Request # 1 | Download start date-time: 2025-01-24 10:17:51.000000. File last date-time: 2025-01-24 10:17:51.090001 2025-01-24 10:40:06.761 | HD Request # 1 | Using server: ds28.sierracharts.com port 10150 2025-01-24 10:40:06.783 | Socket (3) | Creating socket. 2025-01-24 10:40:06.783 | Socket (3) | New receive buffer size: 0 2025-01-24 10:40:06.783 | Socket (3) | Connecting to IP: 67.214.125.5. 2025-01-24 10:40:06.873 | HD Request # 1 | Setting DTC encoding to Binary VLS 2025-01-24 10:40:06.873 | HD Request # 1 | Sending historical data logon request message. 2025-01-24 10:40:06.957 | HD Request # 1 | Requesting Intraday data. Start date-time: 2025-01-24 10:17:51. Record interval: 0. Symbol: MESH25 2025-01-24 10:40:06.999 | HD Request # 1 | Decompressing data. 2025-01-24 10:40:07.053 | HD Request # 1 | Receiving Intraday data for MESH25_FUT_CME starting at 2025-01-24 10:17:51.058000 2025-01-24 10:40:07.162 | Socket (3) | CloseSocket call. 2025-01-24 10:40:07.162 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-01-24 10:40:07.162 | Historical data download thread signaled to stop. 2025-01-24 10:40:07.163 | HD Request # 1 | Timestamp of first Intraday data file record written: 2025-01-24 10:17:51.215000. 2025-01-24 10:40:07.163 | HD Request # 1 | Received 19079 Intraday data records from 2025-01-24 10:17:51.058000 to 2025-01-24 10:40:04.595000 (22.2 minutes. Delay: 2.6 seconds) and wrote 19076 records for MESH25_FUT_CME 2025-01-24 10:40:07.172 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2025-01-24 15:40:04.595000 2025-01-24 10:40:07.172 | Added 11 Time and Sales records to Intraday data file for MESH25_FUT_CME after download. 2025-01-24 10:40:07.172 | HD Request # 1 | Completion time: 1s. 2025-01-24 10:40:07.172 | HD Request # 1 | Intraday data download complete for MESH25_FUT_CME. Unique request ID: 1 2025-01-24 10:40:07.172 | Removing historical data download ID 1. 2025-01-24 10:40:07.172 | Real-time Intraday chart data file updates started for MESH25_FUT_CME 2025-01-24 10:40:07.172 | Intraday chart data file opened for MESH25_FUT_CME 2025-01-24 10:40:07.172 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2025-01-24 10:40:07.172 | 2025-01-24 10:40:07.172 | No download requests in the queue to start downloads for. 2025-01-24 10:40:07.200 | Socket (3) | Socket gracefully closed by remote side. 2025-01-24 10:40:07.200 | Socket (3) | Closed. 2025-01-24 10:40:08.665 | Unsubscribed from market depth data for MESH25_FUT_CME 2025-01-24 10:40:11.024 | Opened cached Intraday file: C:\SierraChart2\Data\MESH25_FUT_CME.scid. Thread ID: 10032 2025-01-24 10:40:12.710 | MESH25_FUT_CME #3 | Reloading chart. 2025-01-24 10:40:12.710 | MESH25_FUT_CME #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-24 10:40:12.711 | MESH25_FUT_CME #3 | Chart data loading complete. 2025-01-24 10:40:12.867 | MESH25_FUT_CME 1 Min #1 | Reloading chart. 2025-01-24 10:40:13.047 | MESH25_FUT_CME 5 Min #2 | Reloading chart. 2025-01-24 10:40:13.663 | Requesting market depth updates for: MESH25_FUT_CME if supported. NumLevels=100 2025-01-24 10:40:13.796 | Denali Data Feed | Clearing market depth for MESH25_FUT_CME 2025-01-24 10:40:14.885 | MESH25_FUT_CME[M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-24 10:40:14.893 | MESH25_FUT_CME[M] 1 Min #1 | Chart data loading complete. 2025-01-24 10:40:15.011 | MESH25_FUT_CME[M] 5 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-24 10:40:15.024 | MESH25_FUT_CME[M] 5 Min #2 | Chart data loading complete. 2025-01-24 10:47:17.162 | DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. * 2025-01-24 10:47:17.162 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-01-24 10:47:17.163 | DTC Client socket (1) | CloseSocket call. 2025-01-24 10:47:17.163 | DTC Client socket (1) | Signaling for receive thread to end. Bytes in receive buffer: 0 2025-01-24 10:47:17.164 | DTC Client socket (1) | Max send buffers used during socket life: 3 2025-01-24 10:47:17.164 | DTC Client socket (1) | Max send buffer size during socket life: 329 2025-01-24 10:47:17.164 | DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. 2025-01-24 10:47:17.164 | Connection to the external service has been lost. 2025-01-24 10:47:17.164 | DTC Client socket (1) | Closed. 2025-01-24 10:47:17.177 | DTC Client socket (0) | CloseSocket call. 2025-01-24 10:47:17.177 | Teton CME Routing | Disconnected. 2025-01-24 10:47:17.177 | Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. 2025-01-24 10:47:19.176 | 2025-01-24 10:47:19.177 | Teton CME Routing | Firm: AMP 2025-01-24 10:47:19.177 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 10:47:19.211 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2025-01-24 10:47:19.211 | DTC Client socket (1) | New receive buffer size: 0 2025-01-24 10:47:19.211 | DTC Client socket (1) | Connecting to IP: 208.185.224.130. 2025-01-24 10:47:19.262 | Teton CME Routing | Network connection to server complete. 2025-01-24 10:47:19.262 | Teton CME Routing | Starting socket receive thread. 2025-01-24 10:47:19.262 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2025-01-24 10:47:19.377 | Teton CME Routing | Setting DTC encoding to Binary VLS 2025-01-24 10:47:19.377 | Teton CME Routing | Sending logon request message. 2025-01-24 10:47:19.478 | Teton CME Routing | Received logon response. 2025-01-24 10:47:19.478 | Teton CME Routing | Server Name: SC DTC Server. Build=51672. 2025-01-24 10:47:19.478 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2025-01-24 10:47:19.478 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2025-01-24 10:47:19.478 | Teton CME Routing | Trading is supported. 2025-01-24 10:47:19.478 | Teton CME Routing | Order cancel and replace is supported. 2025-01-24 10:47:19.478 | Teton CME Routing | OCO Orders supported. 2025-01-24 10:47:19.478 | Teton CME Routing | Bracket Orders supported. 2025-01-24 10:47:19.478 | Teton CME Routing | MarketDepthIsSupported: 1 2025-01-24 10:47:19.478 | Teton CME Routing | Connected to server complete. 2025-01-24 10:47:19.479 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-01-24 10:47:19.479 | Updated verified funded futures trading account ending date to: 2025-02-23 15:47:19 2025-01-24 10:47:19.485 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2025-01-24 10:47:19.489 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2025-01-24 14:59:55.584011 2025-01-24 10:47:19.524 | Updated verified funded futures trading account ending date to: 2025-02-23 15:47:19 2025-01-24 10:47:19.602 | Teton CME Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=166331 2025-01-24 10:47:19.677 | Teton CME Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=166331A 2025-01-24 11:37:48.118 | File >> Disconnect selected. 2025-01-24 11:37:48.121 | Teton CME Routing | Waiting for socket receive thread to end 2025-01-24 11:37:48.121 | DTC Client socket (1) | CloseSocket call. 2025-01-24 11:37:48.121 | DTC Client socket (1) | Max send buffers used during socket life: 3 2025-01-24 11:37:48.121 | DTC Client socket (1) | Max send buffer size during socket life: 329 2025-01-24 11:37:48.122 | Denali Data Feed | Waiting for socket receive thread to end 2025-01-24 11:37:48.122 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2025-01-24 11:37:48.122 | DTC Client socket (2) | CloseSocket call. 2025-01-24 11:37:48.122 | Denali Data Feed | Disconnected from the server. 2025-01-24 11:37:48.122 | Teton CME Routing | Disconnected. 2025-01-24 11:37:48.122 | DTC Client socket (2) | Shutdown started. Waiting for graceful close. 2025-01-24 11:37:48.159 | DTC Client socket (1) | Socket gracefully closed by remote side. 2025-01-24 11:37:48.159 | DTC Client socket (1) | Closed. 2025-01-24 11:37:48.235 | DTC Client socket (2) | Socket gracefully closed by remote side. 2025-01-24 11:37:48.235 | DTC Client socket (2) | Closed. 2025-01-24 11:38:00.926 | 2025-01-24 11:38:00.926 | Teton CME Routing | Firm: AMP 2025-01-24 11:38:00.926 | Teton CME Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11067 2025-01-24 11:38:00.957 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2025-01-24 11:38:00.957 | DTC Client socket (1) | New receive buffer size: 0 2025-01-24 11:38:00.957 | DTC Client socket (1) | Connecting to IP: 208.185.224.130. 2025-01-24 11:38:00.997 | Teton CME Routing | Network connection to server complete. 2025-01-24 11:38:00.997 | Teton CME Routing | Starting socket receive thread. 2025-01-24 11:38:00.997 | Teton CME Routing | Sending encoding request to server: Binary VLS. Compression: none 2025-01-24 11:38:01.109 | Teton CME Routing | Setting DTC encoding to Binary VLS 2025-01-24 11:38:01.109 | Teton CME Routing | Sending logon request message. 2025-01-24 11:38:01.213 | Teton CME Routing | Received logon response. 2025-01-24 11:38:01.213 | Teton CME Routing | Server Name: SC DTC Server. Build=51672. 2025-01-24 11:38:01.213 | Teton CME Routing | Server protocol version: 8. Client protocol version: 8 2025-01-24 11:38:01.213 | Teton CME Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2025-01-24 11:38:01.213 | Teton CME Routing | Trading is supported. 2025-01-24 11:38:01.213 | Teton CME Routing | Order cancel and replace is supported. 2025-01-24 11:38:01.213 | Teton CME Routing | OCO Orders supported. 2025-01-24 11:38:01.213 | Teton CME Routing | Bracket Orders supported. 2025-01-24 11:38:01.213 | Teton CME Routing | MarketDepthIsSupported: 1 2025-01-24 11:38:01.213 | Teton CME Routing | Connected to server complete. 2025-01-24 11:38:01.214 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-01-24 11:38:01.214 | Updated verified funded futures trading account ending date to: 2025-02-23 16:38:01 2025-01-24 11:38:01.219 | Teton CME Routing | Performing query for most recent Order Activity Date-Time. 2025-01-24 11:38:01.224 | Teton CME Routing | Requesting historical order activity from server. Start date-time UTC: 2025-01-24 16:12:54.504677 2025-01-24 11:38:01.256 | Updated verified funded futures trading account ending date to: 2025-02-23 16:38:01 2025-01-24 11:38:01.343 | Mapping MESH25_FUT_CME to MESH25. Service code: cme 2025-01-24 11:38:01.343 | Using symbol data fast lookup vector 2025-01-24 11:38:01.343 | Denali Data Feed | Starting real-time market data updates for: MESH25_FUT_CME (MESH25). ID: 1 Service code: cme 2025-01-24 11:38:01.343 | Denali Data Feed | Connecting to the server ds25.sierracharts.com. Port 443 2025-01-24 11:38:01.343 | Denali Data Feed | Requesting security definition data for: MESH25_FUT_CME (MESH25). ID: 1 2025-01-24 11:38:01.343 | Added historical Intraday data request for MESH25_FUT_CME to the queue. 2025-01-24 11:38:01.343 | Intraday data recording state for symbol MESH25_FUT_CME is set to download 'Pending'. 2025-01-24 11:38:01.343 | Triggering next historical data download in queue. 2025-01-24 11:38:01.371 | DTC Client socket (2) | Creating socket. 2025-01-24 11:38:01.371 | DTC Client socket (2) | New receive buffer size: 0 2025-01-24 11:38:01.371 | DTC Client socket (2) | Connecting to IP: 64.152.155.20. 2025-01-24 11:38:01.391 | Delaying start of download for MESH25_FUT_CME. 2025-01-24 11:38:01.392 | Teton CME Routing | Received final trade activity snapshot. Count=16. TradeAccount=166331 2025-01-24 11:38:01.404 | Denali Data Feed | Network connection to server complete. 2025-01-24 11:38:01.404 | Denali Data Feed | Starting socket receive thread. 2025-01-24 11:38:01.404 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-01-24 11:38:01.409 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESH25_FUT_CME 2025-01-24 11:38:01.409 | Teton CME Routing | Setting external service identifier for symbol MESH25_FUT_CME to 42005347 2025-01-24 11:38:01.409 | Teton CME Routing | Received security definition for symbol MESH25_FUT_CME 2025-01-24 11:38:01.449 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-01-24 11:38:01.449 | Denali Data Feed | Sending logon request message. 2025-01-24 11:38:01.453 | Teton CME Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=166331A 2025-01-24 11:38:01.950 | Denali Data Feed | Received logon response. 2025-01-24 11:38:01.950 | Denali Data Feed | Server Name: SC Realtime Server. 2025-01-24 11:38:01.950 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-01-24 11:38:01.950 | Denali Data Feed | Successfully connected. 2025-01-24 11:38:01.950 | Denali Data Feed | Trading is not supported. 2025-01-24 11:38:01.950 | Denali Data Feed | MarketDepthIsSupported: 1 2025-01-24 11:38:01.950 | Denali Data Feed | Restarting real-time data updates for symbol: MESH25_FUT_CME -> MESH25 2025-01-24 11:38:02.078 | Denali Data Feed | Setting external service identifier for symbol MESH25_FUT_CME to 42005347 2025-01-24 11:38:02.078 | Denali Data Feed | Received security definition for symbol MESH25_FUT_CME 2025-01-24 11:38:06.201 | Requesting market depth updates for: MESH25_FUT_CME if supported. NumLevels=100 2025-01-24 11:38:06.260 | Denali Data Feed | Clearing market depth for MESH25_FUT_CME 2025-01-24 11:38:07.217 | HD Request # 2 | Downloading Intraday chart data for MESH25_FUT_CME to the file MESH25_FUT_CME.scid. Service: cme 2025-01-24 11:38:07.218 | HD Request # 2 | Download start date-time: 2025-01-24 10:57:33.000000. File last date-time: 2025-01-24 10:57:33.803002 2025-01-24 11:38:07.218 | HD Request # 2 | Using server: ds32.sierracharts.com port 10149 2025-01-24 11:38:07.237 | Socket (3) | Creating socket. 2025-01-24 11:38:07.237 | Socket (3) | New receive buffer size: 0 2025-01-24 11:38:07.237 | Socket (3) | Connecting to IP: 67.214.125.3. 2025-01-24 11:38:07.321 | HD Request # 2 | Setting DTC encoding to Binary VLS 2025-01-24 11:38:07.321 | HD Request # 2 | Sending historical data logon request message. 2025-01-24 11:38:07.405 | HD Request # 2 | Requesting Intraday data. Start date-time: 2025-01-24 10:57:33. Record interval: 0. Symbol: MESH25 2025-01-24 11:38:07.441 | HD Request # 2 | Decompressing data. 2025-01-24 11:38:07.602 | Socket (3) | CloseSocket call. 2025-01-24 11:38:07.602 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-01-24 11:38:07.602 | Historical data download thread signaled to stop. 2025-01-24 11:38:07.602 | HD Request # 2 | Received 22562 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for MESH25_FUT_CME 2025-01-24 11:38:07.603 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2025-01-24 15:57:33.803002 2025-01-24 11:38:07.603 | HD Request # 2 | Completion time: 0s. 2025-01-24 11:38:07.603 | HD Request # 2 | Intraday data download complete for MESH25_FUT_CME. Unique request ID: 2 2025-01-24 11:38:07.603 | Removing historical data download ID 2. 2025-01-24 11:38:07.603 | Real-time Intraday chart data file updates started for MESH25_FUT_CME 2025-01-24 11:38:07.603 | Intraday chart data file opened for MESH25_FUT_CME 2025-01-24 11:38:07.603 | HD Request # 2 | Enabling Intraday chart updating for symbol. 2025-01-24 11:38:07.603 | 2025-01-24 11:38:07.603 | No download requests in the queue to start downloads for. 2025-01-24 11:38:07.636 | Socket (3) | Socket gracefully closed by remote side. 2025-01-24 11:38:07.636 | Socket (3) | Closed. 2025-01-24 11:47:23.669 | MESH25_FUT_CME[M] 1 Min #1 | Reloading chart. 2025-01-24 11:47:26.101 | MESH25_FUT_CME[M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-24 11:47:26.159 | MESH25_FUT_CME[M] 1 Min #1 | Chart data loading complete. 2025-01-24 11:47:30.743 | MESH25_FUT_CME[M] 1 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 |
[2025-01-24 17:31:00] |
John - SC Support - Posts: 38782 |
The issue is the following from your log, and the other errors like it: | Error getting address info for www.sierrachart.com. Windows error code 11001: No such host is known. *
You are having a DNS issue with your system. Please follow these instructions: https://www.sierrachart.com/index.php?page=doc/helpdetails1.php#DomainNameServiceIssues For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-24 22:15:09] |
User257874 - Posts: 30 |
Hi John, Close all app, shutdown/restart computer, flush the dns, start sierra chart. All good now. thank for your help |
