Date/Time: Tue, 22 Apr 2025 10:29:15 +0000
How do I change default background color based on volume in Numbers Bars?
View Count: 94
[2025-01-24 16:12:27]
User471548 - Posts: 28
I have set up my Numbers Bars using Diagonal Dominant AskVol BidVol Difference - Actual. All well and good, except for prices where both the ask volume and bid volume are non-dominant. At such prices, the background is drawn using the one default background color.
Is it possible that at such prices, the default background color can be drawn based on the volume sizes and diagonal differences? For example:
1. For total volume below 100, default background color is white
2. For total volume between 100 and 200 and the bid diagonal difference is bigger, default background color is light pink.
3. For total volume between 100 and 200 and the ask diagonal difference is bigger, default background color is light purple.
4. For total volume more than 200 and the bid diagonal difference is bigger, default background color is pink.
5. For total volume more than 200 and the ask diagonal difference is bigger, default background color is purple.
No threshold is needed for the comparison. Thanks.
