Date/Time: Fri, 20 Sep 2024 05:51:03 +0000
Could you please explain this message in the Log
View Count: 815
[2014-09-17 20:30:52] |
EllenT - Posts: 21 |
Received this message in the Trade Service Log. OEC FIX/FAST: There is currently an outstanding position request in progress for the account. The new position request has not been made. | 2014-09-17 10:58:53 What does " position request" refer to? A trade position? I don't trade directly from Sierra. Puzzled. ES |
[2014-09-17 21:29:47] |
This does refer to a Trade Position. The message can be disregarded. It is not that important other than to indicate the OEC server is slow. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
