Date/Time: Tue, 22 Apr 2025 10:17:26 +0000
UPDATING CHARTBOOK
View Count: 130
[2025-01-24 11:43:09] |
usataFX - Posts: 2 |
Good day, Please I need help converting a Sierra chartbook to make it compatible with the current version, I bought a course online and the chartbook was given to us for Sierra chart but anytime i try to open it it displays the message "The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it". I would really appreciate if you help me solve this problem so I can start trading. Thanks Alot. |
[2025-01-24 15:24:38] |
Refer to the following: Chartbooks (Workspaces): Opening Older Chartbooks But if you received this chartbook from a course, you should talk to the company that runs the course and get an appropriate chartbook from them. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
