Date/Time: Tue, 15 Apr 2025 14:27:27 +0000
how do i re-name a chart within a chartbook?
View Count: 3590
[2014-09-17 20:06:13] |
User77503 - Posts: 48 |
I would like to rename my charts, not the chartbook, but I cant figure out how to do so. what am i missing?
[2014-09-17 21:52:14] |
Do you mean change the symbol of a chart? We do not know exactly what is meant by renaming the chart.
[2014-09-17 22:14:13] |
Sawtooth - Posts: 4201 |
Go to Chart >> Chart Settings >> Advanced Settings2 tab >> Title Bar Name and enter a name. Then check 'Use Title Bar Name As Tab Label' Date Time Of Last Edit: 2014-09-17 22:27:06
[2014-09-17 22:18:38] |
See photo.
Attachment Deleted. |
[2014-09-17 22:22:35] |
@tomgilb- got it, exactly what I wanted, thanks!
[2023-03-10 04:05:38] |
User509533 - Posts: 72 |
Hello, I do not see Advanced Settings2 tab under chart settings. Is there any easy way to rename my chart (not chart book) not a new symbol. Cheers! Date Time Of Last Edit: 2023-03-10 04:06:04
[2023-03-10 13:04:55] |
That setting is now on the Display tab. The new Chart Settings windows have a search bar; very helpful. |
[2024-01-10 22:32:34] |
User676363 - Posts: 82 |
True, it's under Display > Title Bar Name And that's useful if the chart is detached. If it is attached and has an MDI (multiple document interface) with title bar, then you can also click on the square menu at the upper left of the window and there you will fine "rename". It will allow you to change the name a bit easier in most cases I think. |
[2024-07-21 11:26:20] |
User754716 - Posts: 11 |
Candle sticks bars not showing in the foot print chart. Only the text shows.
[2024-07-22 14:06:49] |
John - SC Support - Posts: 39275 |
We are not understanding this, and we do not see how this is related to the rest of this thread. If you are having a problem that is not related to changing the name of a chart, then you should post in a new thread. Also, we need more information on what you are asking. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-03-31 17:33:59] |
ROI+ - Posts: 10 |
Hello. I was able to change the name of a chart. How do I go back to the default of the title bar showing ticker and time interval?
[2025-03-31 19:38:54] |
Refer to the following setting: Chart Settings: Title Bar Name (Chart >> Chart Settings >> Display >> Chart Display Items menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
