Date/Time: Mon, 15 Dec 2025 09:11:50 +0000
Initialization error: Sub Instance
View Count: 261
[2025-01-24 03:47:50]
User699988 - Posts: 12
Dear Sierra Team,
I updatet my Sierra Software, it is a Chart Instance 2 which I use for SC Data Services. Since the Update was installed, I cannot start Sierra anymore. It Says: "Initialization error: This is a Sub Instance. It must only be started with File >> New Instance." I also noticed that the Software crashed relatively often just before downloading the update, which was the reason, why I downloaded the update in the beginning.
Can you help me?
Thank you in advance.
[2025-01-24 15:00:59]
Sierra_Chart Engineering - Posts: 21843
We apologize for this. We will solve this today with a new version. Just give us about 30 minutes.
For the time being, go back to an earlier version. To do that, follow the instructions here (Full Control Rollback Procedure):
Software Download: Full Control Rollback Procedure
Install the version 2732.
Date Time Of Last Edit: 2025-01-24 15:01:36
