Date/Time: Tue, 22 Apr 2025 02:18:43 +0000
new chartbook tab
View Count: 181
[2025-01-23 23:57:42] |
User472677 - Posts: 362 |
i want another chartbook tab to show on the bar. how?
[2025-01-24 15:08:42] |
Open another chartbook. However many chartbooks are opened will be reflected in the number of Chartbook tabs that are displayed. Refer to the following: Chartbooks (Workspaces): To Open a Chartbook For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-28 02:54:17] |
My question is different.i want another chartbook tab to show on the bar. how?
[2025-01-28 16:14:14] |
We have no idea what you are asking for since our previous answer did not answer it. Please give us more specific information on what you are wanting.
[2025-02-02 02:24:55] |
In main sierra window, under the main menu, o want tabs for each open chartbook. It used to work fine. Now tabs show only two of the four open chartbooks. All four charbooks are im the startup list.
[2025-02-03 16:51:51] |
Any open chartbooks should be showing as a tab in the Chartbook tabs. Make sure you really have 4 chartbooks open by selecting the "CB" menu item. You should have an exact match to the list of chartbooks in that menu to the chartbook tabs that are open. If you do not have these two matching up, then please get us a screenshot showing your Sierra Chart software with the CB menu open so we can see what it states in it and see the tabs you are referring to. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
