Date/Time: Tue, 22 Apr 2025 10:23:23 +0000
Question about Data Feeds
View Count: 111
[2025-01-23 18:23:23]
User681029 - Posts: 5
Hi SC, I want to use the Denali data feed for CME real time data. I also trade forex. Can I have the CME Data and the Sierra Charts real time Forex and CDF Data displayed at the same time.
[2025-01-23 22:14:13]
John - SC Support - Posts: 39395
It depends on what trading service you are using for trading the CME Group.
If you are using the "Teton Order Routing Service", then you can open charts for FOREX and CFDs within the same installation of Sierra Chart.
Any other service (CQG, Rithmic, Interactive Brokers) would require that you install a separate Sierra Chart and leave the "Current Selected Service" set to "SC Data", which will allow you to get the FOREX and CFD data in that installation, whereas you will get the CME data to your other installation.
