Date/Time: Tue, 22 Apr 2025 10:29:17 +0000
Days to Load for Intraday Chart Data Type
View Count: 169
[2025-01-23 08:48:13] |
User515048 - Posts: 2 |
I have the 'Days to Load for Intraday Chart Data Type' parameter set to 360 days, but on the TPO Chart I see only 2 months. Why?
[2025-01-23 09:51:23] |
Tr00pz - Posts: 20 |
Chart Settings > Symbol > Continuous Contract. You need this turned on if you don't already. I personally use 'Volume Based Rollover, Back Adjusted' Continuous Futures Contract Charts: Introduction |
[2025-01-24 09:02:28] |
Thanks for your reply. Yes, I also have the 'Volume Based Rollover, Back Adjusted' setting. The strange thing is that the standard candlestick chart is OK and covers a few YEARS back. The TPO chart only covers 2 months. |
[2025-01-24 15:14:20] |
If you remove the TPO study and the regular candlestick chart is showing the few years that you are wanting, then the TPO study will cover that same time period. If you believe it is not, then check the time period for your TPO chart to ensure that it is set to the period you want. We wonder if you are expecting days, but it is really set to weeks. Also, scroll back to the beginning of the chart and check the actual first date that is listed, as it should match up with the first bar in your candlestick chart. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
