Date/Time: Mon, 15 Dec 2025 09:11:41 +0000
Spreadsheet for Trading - Expand functionality of Disable Auto Trading J28
View Count: 340
| [2025-01-22 23:39:57] |
| User374751 - Posts: 41 |
Support, Please consider additonal functionality that will expand the Disable Auto Trading option. Consider an option that will also support Disable Entries only, and will allow Exits, to include cell J29, Flatten and Cancel Working Orders. The issue is Disable Auto Trading, cell J28, prevents all actions by the spreadsheet, when the most important action is to prevent entries. If the system is in trade and then the Disable function is activated, it will not allow the system to exit based upon the spreadsheet parameters. This is not ideal nor useful. I have set time parameters within the entry formulas, as an attempt to limit entries. However, the unintended consequence is that the system will not show the entry arrows until the set parameter time. Moreover, under the current logic structure, the Count Bars since Event formulas are also deactivated until the system recognizes the set time within the entry formulas. Again, this is not ideal nor useful. I would rather use the Disable Auto Trade cell J28. The current Disable Auto Trade function provides the ability to limit system actions and still provides the visual arrows I expect to see. The additional functionality I seek will provide the necessary Exit option and still maintain the visual representations of potential entries that I can engage, as well as allow continuous functionality of the Count Bars since Event formulas. I don't use the Exit columns to circumvent any Auto Trade issues that can arise, as stated in the literature, "one solution to avoid the Position being reversed when using both Attached Orders and BuyExit or SellExit, when using the Spreadsheet System for Trading study, is to not use BuyExit or SellExit cells. Instead use the Flatten and Cancel Working Orders special Sheet Input to flatten the Position..." found here:Automated Trading Management: CancelAllWorkingOrdersOnExit Thank you. |
| [2025-01-23 00:25:22] |
| Sierra_Chart Engineering - Posts: 21843 |
You need to create your own custom automated trading system using ACSIL to accomplish what you need: Automated Trading From an Advanced Custom Study There is no chance there is going to be any changes for many years. We are years behind and there is no point in making any requests at this time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-01-23 01:36:36] |
| Sawtooth - Posts: 4299 |
This ability already exists if you reference J8=0 in the formula, like in these examples:Spreadsheet Example Formulas and Usage: Disable Autotrading Outside of Regular Trading Hours However, the documentation doesn't mention this ability. This will allow exits after the time window, but disallow entries. It will also allow J29 to function. (This also means the flatten time in J29 needs to be >= the latest time in J28.) This is the primary reason I personally don't use J85-J89. Date Time Of Last Edit: 2025-01-23 01:39:49
| [2025-01-23 02:47:08] |
Sawtooth, Thanks for the information. Time and agian, you are a true source of reliable information from the community. I am surprised that Engineering could not provide this information in their response, albeit in the literature, which I fervently read before I think to contact Sierra. After the review of the link provided, I admit the functionality does exist as stated in the literature. I just omitted the necessity of J8=0 in my previous formulas. Date Time Of Last Edit: 2025-01-23 03:12:28
