Date/Time: Fri, 20 Sep 2024 05:53:19 +0000
Incorrect daily Highs
View Count: 926
[2014-09-17 19:28:15] |
tom85308 - Posts: 23 |
I've noticed a problem where the highs on the daily chart does not match Infinity's highs listed on their DOM. After reviewing the 60 minute charts it appears that Infinity is correct and the data on the daily chart is incorrect. I have noticed this many times before. For example, at 3:15 PM EST, ES had a high of 2002.75, daily chart was 2004.75. For YM Infinity high was 17131, chart daily high was 17173 and TF high on Infinity DOM was 1155.0, the daily chart was 1158.5. For some reason NQ checked out correct. Can you explain why this happens?
[2014-09-17 21:30:54] |
Refer to help topic 12.2 here: http://www.sierrachart.com/index.php?page=doc/helpdetails12.html#h12.2 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-17 21:32:26
[2014-09-17 21:32:36] |
The prior post has been corrected.
