Date/Time: Tue, 22 Apr 2025 10:26:15 +0000
re: Unable to Scale out of positions
View Count: 150
[2025-01-22 22:39:29] |
vmitrader96 - Posts: 17 |
Hi, I received this message while trying to scale out of a position today. I am trading three Bulenox accounts using the Simple System Trading copier V2. Their support said it was on the SC side, thoughts?
[2025-01-22 23:02:48] |
The message is from Rithmic, so it is related to Bulenox/Rithmic, and not to us specifically. But the general idea is that Rithmic rejected the order since it would exceed an order limit. We do not know what limit or why this is an issue for Rithmic. It is something you would need to take up with them as to what the message specifically means and why you got that message at that time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
