Date/Time: Tue, 22 Apr 2025 10:20:21 +0000
[User Discussion] - How can I create a diagonal difference horizontal bar chart on a 8 price level range chart
View Count: 95
[2025-01-22 20:54:40] |
User669552 - Posts: 26 |
Does any one know how to create a Ascil study that draws a horizontal bar graph on each price level of a 8 tick range chart ( 8 price level range chart). Each price level would should diagonal Bid Volume and Ask Volume differences. The difference would be calculated using Actual volume not percentage. When the difference is positive the horizontal bar would be green. When the difference is negative the horizontal bar would be red. If it could also highlight the POC in the bar I would greatly appreciate. Sierra Number bar does not support this using Actual Volume.
