Date/Time: Tue, 22 Apr 2025 10:32:32 +0000
I deleted by accident "to connect only to known symbols"
View Count: 121
[2025-01-22 18:24:13]
User266036 - Posts: 26
Smaller problem but need help.
Now it says "symbol not found for current services". I cannot find where to connect to symbols found for current services
Please help. I have had to delete and reset each dome symbol, but some are still having problems
Thanks, L
[2025-01-22 20:10:53]
John - SC Support - Posts: 39395
We have no idea what you are referring to in terms of "I deleted by accident "to connect only to known symbols"". What is this?
In general, the symbols are found in "File >> Find Symbol". This will list the correct symbols for the service you are connected to. If you need more help, then let us know.
[2025-01-22 20:44:04]
I am trying to switch to Teton CME routing, but same problem. I used to have Teton, but no luck getting it to not switch to simulated trading same as with SC data
Larry
[2025-01-22 22:33:14]
Make sure you are following all the steps at the following link, starting at Step #7 to connect your Sierra Chart to your Teton Order Routing account:
Sierra Chart Teton Futures Order Routing: Setup Instructions
If you get an error, when connecting to your Teton account, then we need to know what the error states.
