Date/Time: Tue, 22 Apr 2025 10:20:25 +0000
How do I make label color (yellow) match line color (Cyan) in current price study?
View Count: 158
[2025-01-22 13:32:04]
G0ldDigger - Posts: 5
How do I make label color (yellow) match line color (Cyan) in current price study? I can't figure it out for some reason.
See attached.
imagecurrent-price.png / V - Attached On 2025-01-22 13:31:48 UTC - Size: 265.94 KB - 38 views
[2025-01-22 19:06:09]
John - SC Support - Posts: 39395
It is the same color. The issue is that you can not see the actual label as it is underneath the "Last Trade Price Box" which you have set to be a Yellow color. If you look closely at that price, you will see a small line of the blue at the top of the yellow, which is the Current Price Line being drawn one pixel higher than the Last Trade Price Box.
If you do not want the Last Trade Box and just want the last price displayed by the "Current Price Line" label, then disable the option for "Last Trade Price Box" in the Graphics Settings. Refer to the following:
Graphics Settings: Last Trade Price Box
