Date/Time: Tue, 22 Apr 2025 10:29:14 +0000
Bug: Unable to align volume profile to right with all three right align options turned on
View Count: 130
[2025-01-22 05:00:12] |
ghost_in_shell - Posts: 4 |
Unable to align volume profile to right, this problem has occured on my number bars graph. I have turned on right algin Volume bars,align to far right and allow side by side profile on right side. But... It doesn't work..please check out my uploaded chart, you can see a 5-bar volume profile in the middle of the screen. I plan to add POC and delta volume profile as well, but right now I can not do that because of this issue. I'm not sure, maybe because I'm using VP for my number bars it caused a bug with additional VP alignment, is there anywhere around? Thanks |
Private File |
[2025-01-22 17:36:49] |
The reason for what you are seeing is due to the DOM Graph. You have the DOM Graph set to have a width of 5 bars, which when you are viewing the Numbers Bars is a relatively wide space. This is pushing the Volume Profile further to the left. You can do a couple of things: - Reduce the number of bars taken up by the DOM Graph. Refer to the following: Chart Settings: Width in Bars (Chart >> Chart Settings >> Market Depth >> DOM Graph menu) - Set the Input for the Volume Profile for "Do Not Ovelap DOM Graph" to "No". Refer to the following: Volume By Price Study: Do Not Overlap DOM Graph For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
