Date/Time: Mon, 21 Apr 2025 23:30:21 +0000
Error in Message Log
View Count: 107
[2025-01-21 21:42:17] |
User841161 - Posts: 275 |
I am ususally running 4 instances of Sierra Chart. I noticed this error on Message Log. What may be the problem? 2025-01-21 15:31:24.520 | UDPListener (1668). Port 22904 | Error binding to UDP port: 22904. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. |
[2025-01-22 16:39:57] |
Depending on what you are doing, that may not be an issue at all. How are you running the 4 instances? How many are started using "File >> New Instance" and how many are actually separate installations? For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-11 04:37:56] |
Sierra_Chart Engineering - Posts: 19290 |
In those sub instances set this to 0: Sierra Chart Server Settings: UDP Port (Global Settings >> Sierra Chart Server Settings >> General >> General) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
