Date/Time: Tue, 22 Apr 2025 10:23:19 +0000
Teton Moving Attached Orders
View Count: 131
[2025-01-21 16:31:33] |
ForgivingComputers.com - Posts: 1042 |
I am using NewOrder.Target1Price and when the parent order fills, the target is being modified by Teton Order Routing: Teton CME Routing (Order update). Info: Modifying Attached Order from parent fill.
This is causing the stop to move by 3 ticks. How do I prevent this? Is there a setting in the Teton setup? |
[2025-01-21 19:06:37] |
Check your setting for the following and make sure it is set the way you want: Global Trade Settings Windows: Adjust Attached Orders to Maintain Same Offset on Parent Fill (Global Settings >> General Trade Settings >> General) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
