Date/Time: Mon, 05 Oct 2026 17:05:00 +0000
The [M] is not staying on.
View Count: 1318
| [2025-01-21 16:18:54] |
| User757746 - Posts: 20 |
When restarting SC the [M] has disappeared and I have to go to Charts>symbol to activate on each chart. Can not figure out how to keep it in place ..
| [2025-01-21 19:01:50] |
| John - SC Support - Posts: 48101 |
That indicator should not come and go. It should either be there, or not be there. The one thing to consider is that the [M] indicator will not show on charts that are in a Sub-Instance (started with File >> New Instance) even though it will show in the Main Instance. This is normal and nothing to be concerned about. If you are really seeing this going in and out, then we would need to see your Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-01-21 22:06:53] |
2025-01-21 12:16:31.820 | Trade activity files set size: 372 2025-01-21 12:16:31.949 | Reading Internal Order ID file. 2025-01-21 12:16:32.003 | Reading Trade Orders file. 2025-01-21 12:16:32.003 | Reading Trade Positions file. 2025-01-21 12:16:32.003 | Reading Trade Account Data files. 2025-01-21 12:16:32.028 | Software version: 2726 64-bit 2025-01-21 12:16:32.028 | Primary Thread ID: 153688 2025-01-21 12:16:32.028 | Usage end date: 2025-02-23 2025-01-21 12:16:32.028 | Enabled for: Sierra Chart Historical Data Service. 2025-01-21 12:16:32.028 | Enabled for: Denali Real-Time Exchange Data Feed. 2025-01-21 12:16:32.028 | Enabled for: Delayed Denali Exchange Data Feed. 2025-01-21 12:16:32.028 | Enabled for exchange2: CME (Trading Account Required) 2025-01-21 12:16:32.028 | Enabled for exchange2: CBOT (Trading Account Required) 2025-01-21 12:16:32.028 | Enabled for exchange2: COMEX (Trading Account Required) 2025-01-21 12:16:32.028 | Enabled for exchange2: NYMEX (Trading Account Required) 2025-01-21 12:16:32.028 | Allow Support for Sierra Chart Data Feeds is enabled. 2025-01-21 12:16:32.028 | Current selected Data/Trading service: Teton CME Order Routing 2025-01-21 12:16:32.028 | Custom symbol settings values: enabled 2025-01-21 12:16:32.028 | Chart Update Interval: 500 2025-01-21 12:16:32.028 | Intraday Data Storage Time Unit: 1 2025-01-21 12:16:32.028 | Time Zone: -07:00:00 (MST-07MDT+01,M3.2.0/02:00,M11.1.0/02:00) 2025-01-21 12:16:32.028 | 2025-01-21 19:16:32 Local computer time in UTC 2025-01-21 12:16:32.028 | 2025-01-21 12:16:32 Local computer time in SC Time Zone 2025-01-21 12:16:32.028 | 2025-01-21 19:16:30 Server time in UTC 2025-01-21 12:16:32.028 | Local computer UTC time and Server UTC time difference: 1 seconds. 2025-01-21 12:16:32.028 | Program path: C:\SierraChart\ 2025-01-21 12:16:32.028 | Data Files path: C:\Users\lbowe\OneDrive\Sierra Charts\Data\ 2025-01-21 12:16:32.028 | OS Version Number: 10.0 2025-01-21 12:16:32.028 | Locale Setting: C 2025-01-21 12:16:32.028 | DLLs: UserContributedStudies_64.dll 2025-01-21 12:16:32.028 | Allowed protected custom studies: 2025-01-21 12:16:32.028 | Crash reporter started: true 2025-01-21 12:16:32.028 | 2025-01-21 12:16:32.040 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. 2025-01-21 12:16:32.063 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2025-01-21 12:16:32.116 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2025-01-21 12:16:32.116 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2025-01-21 12:16:32.235 | Received 5 login tokens. 2025-01-21 12:16:32.638 | Symbol settings MD5 received. Request ID: 1. 2025-01-21 12:16:32.638 | Symbol settings are up-to-date for sc_futures_direct.dtc.trading. 2025-01-21 12:16:34.544 | Requested user files to download. 2025-01-21 12:16:34.857 | File to download: momentum bar ZONE NQ.wav. Action: 0 2025-01-21 12:16:34.857 | User files to download complete 2025-01-21 12:16:36.537 | 2025-01-21 12:16:36.538 | Teton CME Order Routing | Firm: Dorman/Stage5 2025-01-21 12:16:36.539 | Teton CME Order Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11093 2025-01-21 12:16:36.595 | DTC Client socket (1) | Creating socket. Using TLS 1.2. 2025-01-21 12:16:36.595 | DTC Client socket (1) | New receive buffer size: 0 2025-01-21 12:16:36.595 | DTC Client socket (1) | Connecting to IP: 208.185.224.130. 2025-01-21 12:16:36.640 | Teton CME Order Routing | Network connection to server complete. 2025-01-21 12:16:36.640 | Teton CME Order Routing | Starting socket receive thread. 2025-01-21 12:16:36.640 | Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none 2025-01-21 12:16:36.783 | Teton CME Order Routing | Setting DTC encoding to Binary VLS 2025-01-21 12:16:36.783 | Teton CME Order Routing | Sending logon request message. 2025-01-21 12:16:36.894 | Teton CME Order Routing | Received logon response. 2025-01-21 12:16:36.894 | Teton CME Order Routing | Server Name: SC DTC Server. Build=52100. 2025-01-21 12:16:36.894 | Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 2025-01-21 12:16:36.894 | Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading. 2025-01-21 12:16:36.894 | Teton CME Order Routing | Trading is supported. 2025-01-21 12:16:36.894 | Teton CME Order Routing | Order cancel and replace is supported. 2025-01-21 12:16:36.894 | Teton CME Order Routing | OCO Orders supported. 2025-01-21 12:16:36.894 | Teton CME Order Routing | Bracket Orders supported. 2025-01-21 12:16:36.894 | Teton CME Order Routing | MarketDepthIsSupported: 1 2025-01-21 12:16:36.894 | Teton CME Order Routing | Connected to server complete. 2025-01-21 12:16:36.895 | No download requests in the queue to start downloads for. | Number times message added: 3 2025-01-21 12:16:36.895 | Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. 2025-01-21 12:16:36.897 | Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2025-01-21 17:18:31.828109 2025-01-21 12:16:36.939 | Updated verified funded futures trading account ending date to: 2025-02-20 19:16:36 2025-01-21 12:16:37.066 | Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=1140A 2025-01-21 12:16:37.187 | Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=48612 2025-01-21 12:16:45.030 | GCG25_FUT_CME Daily #2 | Reloading chart. 2025-01-21 12:16:45.161 | GCG25_FUT_CME 5 Min #1 | Reloading chart. 2025-01-21 12:16:45.323 | GCG25_FUT_CME Flex Renko 10-7-0 #3 | Reloading chart. 2025-01-21 12:16:45.381 | CLG25_FUT_CME Daily #2 | Reloading chart. 2025-01-21 12:16:45.508 | CLH25_FUT_CME 5 Min #1 | Reloading chart. 2025-01-21 12:16:45.679 | CLH25_FUT_CME Flex Renko 10-7-0 #3 | Reloading chart. 2025-01-21 12:16:45.738 | NQH25_FUT_CME Daily #2 | Reloading chart. 2025-01-21 12:16:45.774 | NQH25_FUT_CME 5 Min #1 | Reloading chart. 2025-01-21 12:16:45.959 | NQH25_FUT_CME Flex Renko 10-7-0 #3 | Reloading chart. 2025-01-21 12:16:46.003 | ESH25_FUT_CME 5 Min #4 | Reloading chart. 2025-01-21 12:16:46.082 | YMH25_FUT_CME Daily #2 | Reloading chart. 2025-01-21 12:16:46.212 | YMH25_FUT_CME 5 Min #1 | Reloading chart. 2025-01-21 12:16:46.388 | YMH25_FUT_CME Flex Renko 10-7-0 #3 | Reloading chart. 2025-01-21 12:16:46.451 | ESH25_FUT_CME Daily #2 | Reloading chart. 2025-01-21 12:16:46.488 | ESH25_FUT_CME 5 Min #1 | Reloading chart. 2025-01-21 12:16:46.666 | ESH25_FUT_CME Flex Renko 10-7-0 #3 | Reloading chart. 2025-01-21 12:16:46.684 | GCG25_FUT_CME Daily #2 | Chart data loading complete. 2025-01-21 12:16:46.693 | GCG25_FUT_CME 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 12:16:46.712 | GCG25_FUT_CME 5 Min #1 | Chart data loading complete. 2025-01-21 12:16:46.719 | CLG25_FUT_CME Daily #2 | Chart data loading complete. 2025-01-21 12:16:46.726 | CLH25_FUT_CME 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 12:16:46.744 | CLH25_FUT_CME 5 Min #1 | Chart data loading complete. 2025-01-21 12:16:46.745 | GCG25_FUT_CME Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 12:16:46.805 | GCG25_FUT_CME Flex Renko 10-7-0 #3 | Chart data loading complete. 2025-01-21 12:16:46.810 | NQH25_FUT_CME Daily #2 | Chart data loading complete. 2025-01-21 12:16:46.826 | CLH25_FUT_CME Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 12:16:46.843 | CLH25_FUT_CME Flex Renko 10-7-0 #3 | Chart data loading complete. 2025-01-21 12:16:46.857 | NQH25_FUT_CME 5 Min #1 | Chart data loading complete. 2025-01-21 12:16:46.866 | YMH25_FUT_CME Daily #2 | Chart data loading complete. 2025-01-21 12:16:46.867 | ESH25_FUT_CME 5 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 12:16:46.881 | ESH25_FUT_CME 5 Min #4 | Chart data loading complete. 2025-01-21 12:16:46.886 | YMH25_FUT_CME 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 12:16:46.897 | YMH25_FUT_CME 5 Min #1 | Chart data loading complete. 2025-01-21 12:16:46.917 | ESH25_FUT_CME Daily #2 | Chart data loading complete. 2025-01-21 12:16:46.923 | YMH25_FUT_CME Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 12:16:46.985 | YMH25_FUT_CME Flex Renko 10-7-0 #3 | Chart data loading complete. 2025-01-21 12:16:47.035 | ESH25_FUT_CME 5 Min #1 | Chart data loading complete. 2025-01-21 12:16:47.038 | NQH25_FUT_CME Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 12:16:47.537 | NQH25_FUT_CME Flex Renko 10-7-0 #3 | Chart data loading complete. 2025-01-21 12:16:48.152 | Mapping ESH25_FUT_CME to ESH25. Service code: cme 2025-01-21 12:16:48.152 | Using symbol data fast lookup vector 2025-01-21 12:16:48.152 | Denali Data Feed | Starting real-time market data updates for: ESH25_FUT_CME (ESH25). ID: 1 Service code: cme 2025-01-21 12:16:48.152 | Denali Data Feed | Connecting to the server ds28.sierracharts.com. Port 443 2025-01-21 12:16:48.152 | Denali Data Feed | Requesting security definition data for: ESH25_FUT_CME (ESH25). ID: 1 2025-01-21 12:16:48.152 | Requesting market depth updates for: ESH25_FUT_CME if supported. NumLevels=100 2025-01-21 12:16:48.152 | Mapping NQH25_FUT_CME to NQH25. Service code: cme 2025-01-21 12:16:48.152 | Denali Data Feed | Starting real-time market data updates for: NQH25_FUT_CME (NQH25). ID: 2 Service code: cme 2025-01-21 12:16:48.152 | Denali Data Feed | Requesting security definition data for: NQH25_FUT_CME (NQH25). ID: 2 2025-01-21 12:16:48.152 | Requesting market depth updates for: NQH25_FUT_CME if supported. NumLevels=100 2025-01-21 12:16:48.152 | Mapping YMH25_FUT_CME to YMH25. Service code: cbot 2025-01-21 12:16:48.152 | Denali Data Feed | Starting real-time market data updates for: YMH25_FUT_CME (YMH25). ID: 3 Service code: cbot 2025-01-21 12:16:48.152 | Denali Data Feed | Requesting security definition data for: YMH25_FUT_CME (YMH25). ID: 3 2025-01-21 12:16:48.152 | Requesting market depth updates for: YMH25_FUT_CME if supported. NumLevels=100 2025-01-21 12:16:48.153 | ESH25_FUT_CME Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 12:16:48.213 | DTC Client socket (2) | Creating socket. 2025-01-21 12:16:48.213 | DTC Client socket (2) | New receive buffer size: 0 2025-01-21 12:16:48.213 | DTC Client socket (2) | Connecting to IP: 67.214.125.5. 2025-01-21 12:16:48.234 | ESH25_FUT_CME Flex Renko 10-7-0 #3 | Chart data loading complete. 2025-01-21 12:16:48.309 | Denali Data Feed | Network connection to server complete. 2025-01-21 12:16:48.309 | Denali Data Feed | Starting socket receive thread. 2025-01-21 12:16:48.309 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard 2025-01-21 12:16:48.309 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH25_FUT_CME 2025-01-21 12:16:48.309 | Teton CME Order Routing | Setting external service identifier for symbol ESH25_FUT_CME to 5002 2025-01-21 12:16:48.309 | Teton CME Order Routing | Received security definition for symbol ESH25_FUT_CME 2025-01-21 12:16:48.309 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: NQH25_FUT_CME 2025-01-21 12:16:48.309 | Teton CME Order Routing | Setting external service identifier for symbol NQH25_FUT_CME to 42288528 2025-01-21 12:16:48.309 | Teton CME Order Routing | Received security definition for symbol NQH25_FUT_CME 2025-01-21 12:16:48.309 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: YMH25_FUT_CME 2025-01-21 12:16:48.309 | Teton CME Order Routing | Setting external service identifier for symbol YMH25_FUT_CME to 42002868 2025-01-21 12:16:48.309 | Teton CME Order Routing | Received security definition for symbol YMH25_FUT_CME 2025-01-21 12:16:48.366 | Denali Data Feed | Setting DTC encoding to Binary VLS 2025-01-21 12:16:48.366 | Denali Data Feed | Sending logon request message. 2025-01-21 12:16:48.385 | Mapping GCG25_FUT_CME to GCG25. Service code: comex 2025-01-21 12:16:48.385 | Denali Data Feed | Starting real-time market data updates for: GCG25_FUT_CME (GCG25). ID: 4 Service code: comex 2025-01-21 12:16:48.385 | Denali Data Feed | Requesting security definition data for: GCG25_FUT_CME (GCG25). ID: 4 2025-01-21 12:16:48.386 | Starting DelayedDownloadMonitoringTimer 2025-01-21 12:16:48.386 | Starting HDTimeoutTimer 2025-01-21 12:16:48.386 | Added historical Intraday data request for GCG25_FUT_CME to the queue. 2025-01-21 12:16:48.386 | Intraday data recording state for symbol GCG25_FUT_CME is set to download 'Pending'. 2025-01-21 12:16:48.386 | Triggering next historical data download in queue. 2025-01-21 12:16:48.387 | Delaying start of download for GCG25_FUT_CME. 2025-01-21 12:16:48.392 | Mapping CLG25_FUT_CME to CLG25. Service code: nymex 2025-01-21 12:16:48.392 | Denali Data Feed | Starting real-time market data updates for: CLG25_FUT_CME (CLG25). ID: 5 Service code: nymex 2025-01-21 12:16:48.392 | Denali Data Feed | Requesting security definition data for: CLG25_FUT_CME (CLG25). ID: 5 2025-01-21 12:16:48.393 | Mapping CLH25_FUT_CME to CLH25. Service code: nymex 2025-01-21 12:16:48.393 | Denali Data Feed | Starting real-time market data updates for: CLH25_FUT_CME (CLH25). ID: 6 Service code: nymex 2025-01-21 12:16:48.393 | Denali Data Feed | Requesting security definition data for: CLH25_FUT_CME (CLH25). ID: 6 2025-01-21 12:16:48.393 | Added historical Intraday data request for CLH25_FUT_CME to the queue. 2025-01-21 12:16:48.393 | Intraday data recording state for symbol CLH25_FUT_CME is set to download 'Pending'. 2025-01-21 12:16:48.393 | Triggering next historical data download in queue. 2025-01-21 12:16:48.397 | Added historical Intraday data request for NQH25_FUT_CME to the queue. 2025-01-21 12:16:48.397 | Intraday data recording state for symbol NQH25_FUT_CME is set to download 'Pending'. 2025-01-21 12:16:48.397 | Triggering next historical data download in queue. 2025-01-21 12:16:48.404 | Added historical Intraday data request for ESH25_FUT_CME to the queue. 2025-01-21 12:16:48.404 | Intraday data recording state for symbol ESH25_FUT_CME is set to download 'Pending'. 2025-01-21 12:16:48.404 | Triggering next historical data download in queue. 2025-01-21 12:16:48.446 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: GCG25_FUT_CME 2025-01-21 12:16:48.446 | Teton CME Order Routing | Setting external service identifier for symbol GCG25_FUT_CME to 1551 2025-01-21 12:16:48.446 | Teton CME Order Routing | Received security definition for symbol GCG25_FUT_CME 2025-01-21 12:16:48.446 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLG25_FUT_CME 2025-01-21 12:16:48.446 | Teton CME Order Routing | Setting external service identifier for symbol CLG25_FUT_CME to 615689 2025-01-21 12:16:48.446 | Teton CME Order Routing | Received security definition for symbol CLG25_FUT_CME 2025-01-21 12:16:48.446 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: CLH25_FUT_CME 2025-01-21 12:16:48.446 | Teton CME Order Routing | Setting external service identifier for symbol CLH25_FUT_CME to 37014 2025-01-21 12:16:48.446 | Teton CME Order Routing | Received security definition for symbol CLH25_FUT_CME 2025-01-21 12:16:48.484 | Added historical Intraday data request for YMH25_FUT_CME to the queue. 2025-01-21 12:16:48.484 | Intraday data recording state for symbol YMH25_FUT_CME is set to download 'Pending'. 2025-01-21 12:16:48.484 | Triggering next historical data download in queue. 2025-01-21 12:16:48.864 | Denali Data Feed | Received logon response. 2025-01-21 12:16:48.864 | Denali Data Feed | Server Name: SC Realtime Server. 2025-01-21 12:16:48.864 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8 2025-01-21 12:16:48.864 | Denali Data Feed | Successfully connected. 2025-01-21 12:16:48.864 | Denali Data Feed | Trading is not supported. 2025-01-21 12:16:48.864 | Denali Data Feed | MarketDepthIsSupported: 1 2025-01-21 12:16:48.864 | Denali Data Feed | Restarting real-time data updates for symbol: CLG25_FUT_CME -> CLG25 2025-01-21 12:16:48.864 | Denali Data Feed | Restarting real-time data updates for symbol: CLH25_FUT_CME -> CLH25 2025-01-21 12:16:48.864 | Denali Data Feed | Restarting real-time data updates for symbol: ESH25_FUT_CME -> ESH25. Market Depth data restarted. 2025-01-21 12:16:48.864 | Denali Data Feed | Restarting real-time data updates for symbol: GCG25_FUT_CME -> GCG25 2025-01-21 12:16:48.864 | Denali Data Feed | Restarting real-time data updates for symbol: NQH25_FUT_CME -> NQH25. Market Depth data restarted. 2025-01-21 12:16:48.864 | Denali Data Feed | Restarting real-time data updates for symbol: YMH25_FUT_CME -> YMH25. Market Depth data restarted. 2025-01-21 12:16:49.050 | Denali Data Feed | Setting external service identifier for symbol CLG25_FUT_CME to 615689 2025-01-21 12:16:49.050 | Denali Data Feed | Received security definition for symbol CLG25_FUT_CME 2025-01-21 12:16:49.050 | Denali Data Feed | Setting external service identifier for symbol CLH25_FUT_CME to 37014 2025-01-21 12:16:49.050 | Denali Data Feed | Received security definition for symbol CLH25_FUT_CME 2025-01-21 12:16:49.050 | Denali Data Feed | Market Depth data has been rejected for symbol: ESH25_FUT_CME. Not authorized for market depth. 2025-01-21 12:16:49.050 | Denali Data Feed | Setting external service identifier for symbol ESH25_FUT_CME to 5002 2025-01-21 12:16:49.050 | Denali Data Feed | Received security definition for symbol ESH25_FUT_CME 2025-01-21 12:16:49.051 | Denali Data Feed | Setting external service identifier for symbol GCG25_FUT_CME to 1551 2025-01-21 12:16:49.051 | Denali Data Feed | Received security definition for symbol GCG25_FUT_CME 2025-01-21 12:16:49.051 | Denali Data Feed | Market Depth data has been rejected for symbol: NQH25_FUT_CME. Not authorized for market depth. 2025-01-21 12:16:49.051 | Denali Data Feed | Setting external service identifier for symbol NQH25_FUT_CME to 42288528 2025-01-21 12:16:49.051 | Denali Data Feed | Received security definition for symbol NQH25_FUT_CME 2025-01-21 12:16:49.051 | Denali Data Feed | Market Depth data has been rejected for symbol: YMH25_FUT_CME. Not authorized for market depth. 2025-01-21 12:16:49.051 | Denali Data Feed | Setting external service identifier for symbol YMH25_FUT_CME to 42002868 2025-01-21 12:16:49.051 | Denali Data Feed | Received security definition for symbol YMH25_FUT_CME 2025-01-21 12:16:49.554 | Starting DelayedDownloadMonitoringTimer 2025-01-21 12:16:49.554 | Starting HDTimeoutTimer 2025-01-21 12:16:49.554 | Added historical Daily data request for GCG25_FUT_CME to the queue. 2025-01-21 12:16:49.555 | Triggering next historical data download in queue. 2025-01-21 12:16:49.556 | HD Request # 1 | Downloading Historical Daily chart data for GCG25_FUT_CME. Starting date: 2025-01-15. Service: sc_futures_direct.dtc.trading 2025-01-21 12:16:49.579 | Added historical Daily data request for YMH25_FUT_CME to the queue. 2025-01-21 12:16:49.579 | Triggering next historical data download in queue. 2025-01-21 12:16:49.737 | Added historical Daily data request for NQH25_FUT_CME to the queue. 2025-01-21 12:16:49.737 | Triggering next historical data download in queue. 2025-01-21 12:16:49.872 | HD Request # 1 | Requesting historical Daily data for GCG25 starting at 2025-01-14. SC External HD service. 2025-01-21 12:16:49.881 | Added historical Daily data request for CLG25_FUT_CME to the queue. 2025-01-21 12:16:49.881 | Triggering next historical data download in queue. 2025-01-21 12:16:49.975 | Added historical Daily data request for ESH25_FUT_CME to the queue. 2025-01-21 12:16:49.975 | Triggering next historical data download in queue. 2025-01-21 12:16:50.221 | HD Request # 1 | Receiving historical Daily data for GCG25_FUT_CME starting at 2025-01-15. 2025-01-21 12:16:50.221 | HD Request # 1 | Writing historical Daily data to the file GCG25_FUT_CME.dly. 2025-01-21 12:16:50.223 | HD Request # 1 | Bytes received: 232 2025-01-21 12:16:50.223 | HD Request # 1 | Received 4 Daily data records from 2025-01-15 00:00:00 to 2025-01-17 00:00:00 (3.0 days) and wrote 3 records for GCG25_FUT_CME 2025-01-21 12:16:50.223 | HD Request # 1 | Completion time: 1s. 2025-01-21 12:16:50.223 | HD Request # 1 | Daily data download complete for GCG25_FUT_CME. Unique request ID: 6 2025-01-21 12:16:50.223 | Removing historical data download ID 6. 2025-01-21 12:16:50.223 | 2025-01-21 12:16:50.223 | Triggering next historical data download in queue. 2025-01-21 12:16:50.224 | HD Request # 2 | Downloading Historical Daily chart data for YMH25_FUT_CME. Starting date: 2025-01-15. Service: sc_futures_direct.dtc.trading 2025-01-21 12:16:50.552 | HD Request # 2 | Requesting historical Daily data for YMH25 starting at 2025-01-14. SC External HD service. 2025-01-21 12:16:50.554 | GCG25_FUT_CME[M] Daily #2 | Reloading chart. 2025-01-21 12:16:50.561 | GCG25_FUT_CME[M] Daily #2 | Chart data loading complete. 2025-01-21 12:16:50.792 | HD Request # 2 | Receiving historical Daily data for YMH25_FUT_CME starting at 2025-01-15. 2025-01-21 12:16:50.793 | HD Request # 2 | Writing historical Daily data to the file YMH25_FUT_CME.dly. 2025-01-21 12:16:50.796 | HD Request # 2 | Bytes received: 215 2025-01-21 12:16:50.796 | HD Request # 2 | Received 4 Daily data records from 2025-01-15 00:00:00 to 2025-01-17 00:00:00 (3.0 days) and wrote 3 records for YMH25_FUT_CME 2025-01-21 12:16:50.797 | HD Request # 2 | Completion time: 0s. 2025-01-21 12:16:50.797 | HD Request # 2 | Daily data download complete for YMH25_FUT_CME. Unique request ID: 7 2025-01-21 12:16:50.797 | Removing historical data download ID 7. 2025-01-21 12:16:50.798 | 2025-01-21 12:16:50.798 | Triggering next historical data download in queue. 2025-01-21 12:16:50.799 | HD Request # 3 | Downloading Historical Daily chart data for NQH25_FUT_CME. Starting date: 2025-01-15. Service: sc_futures_direct.dtc.trading 2025-01-21 12:16:51.084 | YMH25_FUT_CME[M] Daily #2 | Reloading chart. 2025-01-21 12:16:51.092 | YMH25_FUT_CME[M] Daily #2 | Chart data loading complete. 2025-01-21 12:16:51.115 | HD Request # 3 | Requesting historical Daily data for NQH25 starting at 2025-01-14. SC External HD service. 2025-01-21 12:16:51.276 | HD Request # 3 | Receiving historical Daily data for NQH25_FUT_CME starting at 2025-01-15. 2025-01-21 12:16:51.277 | HD Request # 3 | Writing historical Daily data to the file NQH25_FUT_CME.dly. 2025-01-21 12:16:51.281 | HD Request # 3 | Bytes received: 252 2025-01-21 12:16:51.281 | HD Request # 3 | Received 4 Daily data records from 2025-01-15 00:00:00 to 2025-01-17 00:00:00 (3.0 days) and wrote 3 records for NQH25_FUT_CME 2025-01-21 12:16:51.282 | HD Request # 3 | Completion time: 1s. 2025-01-21 12:16:51.282 | HD Request # 3 | Daily data download complete for NQH25_FUT_CME. Unique request ID: 8 2025-01-21 12:16:51.282 | Removing historical data download ID 8. 2025-01-21 12:16:51.283 | 2025-01-21 12:16:51.283 | Triggering next historical data download in queue. 2025-01-21 12:16:51.285 | HD Request # 4 | Downloading Historical Daily chart data for CLG25_FUT_CME. Starting date: 2025-01-15. Service: sc_futures_direct.dtc.trading 2025-01-21 12:16:51.591 | HD Request # 4 | Requesting historical Daily data for CLG25 starting at 2025-01-14. SC External HD service. 2025-01-21 12:16:51.740 | HD Request # 4 | Receiving historical Daily data for CLG25_FUT_CME starting at 2025-01-15. 2025-01-21 12:16:51.740 | HD Request # 4 | Writing historical Daily data to the file CLG25_FUT_CME.dly. 2025-01-21 12:16:51.746 | HD Request # 4 | Bytes received: 215 2025-01-21 12:16:51.746 | HD Request # 4 | Received 4 Daily data records from 2025-01-15 00:00:00 to 2025-01-17 00:00:00 (3.0 days) and wrote 3 records for CLG25_FUT_CME 2025-01-21 12:16:51.746 | HD Request # 4 | Completion time: 0s. 2025-01-21 12:16:51.746 | HD Request # 4 | Daily data download complete for CLG25_FUT_CME. Unique request ID: 9 2025-01-21 12:16:51.746 | Removing historical data download ID 9. 2025-01-21 12:16:51.746 | 2025-01-21 12:16:51.746 | Triggering next historical data download in queue. 2025-01-21 12:16:51.747 | HD Request # 5 | Downloading Historical Daily chart data for ESH25_FUT_CME. Starting date: 2025-01-15. Service: sc_futures_direct.dtc.trading 2025-01-21 12:16:51.767 | NQH25_FUT_CME[M] Daily #2 | Reloading chart. 2025-01-21 12:16:51.771 | NQH25_FUT_CME[M] Daily #2 | Chart data loading complete. 2025-01-21 12:16:51.890 | CLG25_FUT_CME[M] Daily #2 | Reloading chart. 2025-01-21 12:16:51.911 | CLG25_FUT_CME[M] Daily #2 | Chart data loading complete. 2025-01-21 12:16:52.076 | HD Request # 5 | Requesting historical Daily data for ESH25 starting at 2025-01-14. SC External HD service. 2025-01-21 12:16:52.233 | HD Request # 5 | Receiving historical Daily data for ESH25_FUT_CME starting at 2025-01-15. 2025-01-21 12:16:52.234 | HD Request # 5 | Writing historical Daily data to the file ESH25_FUT_CME.dly. 2025-01-21 12:16:52.236 | HD Request # 5 | Bytes received: 245 2025-01-21 12:16:52.236 | HD Request # 5 | Received 4 Daily data records from 2025-01-15 00:00:00 to 2025-01-17 00:00:00 (3.0 days) and wrote 3 records for ESH25_FUT_CME 2025-01-21 12:16:52.236 | HD Request # 5 | Completion time: 1s. 2025-01-21 12:16:52.236 | HD Request # 5 | Daily data download complete for ESH25_FUT_CME. Unique request ID: 10 2025-01-21 12:16:52.236 | Removing historical data download ID 10. 2025-01-21 12:16:52.236 | 2025-01-21 12:16:52.236 | No download requests in the queue to start downloads for. 2025-01-21 12:16:52.490 | ESH25_FUT_CME[M] Daily #2 | Reloading chart. 2025-01-21 12:16:52.522 | ESH25_FUT_CME[M] Daily #2 | Chart data loading complete. 2025-01-21 12:16:54.387 | HD Request # 6 | Downloading Intraday chart data for GCG25_FUT_CME to the file GCG25_FUT_CME.scid. Service: comex 2025-01-21 12:16:54.387 | HD Request # 6 | Download start date-time: 2025-01-21 12:05:10.000000. File last date-time: 2025-01-21 12:05:10.000000 2025-01-21 12:16:54.387 | HD Request # 6 | Using server: ds28.sierracharts.com port 10149 2025-01-21 12:16:54.387 | Socket (3) | Creating socket. 2025-01-21 12:16:54.387 | Socket (3) | New receive buffer size: 0 2025-01-21 12:16:54.387 | Socket (3) | Connecting to IP: 67.214.125.5. 2025-01-21 12:16:54.501 | HD Request # 6 | Setting DTC encoding to Binary VLS 2025-01-21 12:16:54.501 | HD Request # 6 | Sending historical data logon request message. 2025-01-21 12:16:54.595 | HD Request # 6 | Requesting Intraday data. Start date-time: 2025-01-21 12:05:10. Record interval: 1. Symbol: GCG25 2025-01-21 12:16:54.649 | HD Request # 6 | Decompressing data. 2025-01-21 12:16:54.700 | HD Request # 6 | Receiving Intraday data for GCG25_FUT_CME starting at 2025-01-21 12:05:10.457000 2025-01-21 12:16:54.701 | Socket (3) | CloseSocket call. 2025-01-21 12:16:54.701 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-01-21 12:16:54.718 | Historical data download thread signaled to stop. 2025-01-21 12:16:54.718 | HD Request # 6 | Timestamp of first Intraday data file record written: 2025-01-21 12:05:10.457000. 2025-01-21 12:16:54.718 | HD Request # 6 | Received 173 Intraday data records from 2025-01-21 12:05:10.457000 to 2025-01-21 12:16:45.288000 (11.6 minutes. Delay: 9.4 seconds) and wrote 173 records for GCG25_FUT_CME 2025-01-21 12:16:54.725 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2025-01-21 19:16:45.288000 2025-01-21 12:16:54.725 | HD Request # 6 | Completion time: 0s. 2025-01-21 12:16:54.725 | HD Request # 6 | Intraday data download complete for GCG25_FUT_CME. Unique request ID: 1 2025-01-21 12:16:54.725 | Removing historical data download ID 1. 2025-01-21 12:16:54.725 | Real-time Intraday chart data file updates started for GCG25_FUT_CME 2025-01-21 12:16:54.725 | Opened cached Intraday file: C:\Users\lbowe\OneDrive\Sierra Charts\Data\GCG25_FUT_CME.scid. Thread ID: 153688 2025-01-21 12:16:54.725 | Intraday chart data file opened for GCG25_FUT_CME 2025-01-21 12:16:54.725 | HD Request # 6 | Enabling Intraday chart updating for symbol. 2025-01-21 12:16:54.725 | 2025-01-21 12:16:54.725 | Triggering next historical data download in queue. 2025-01-21 12:16:54.725 | HD Request # 7 | Downloading Intraday chart data for CLH25_FUT_CME to the file CLH25_FUT_CME.scid. Service: nymex 2025-01-21 12:16:54.725 | HD Request # 7 | Download start date-time: 2025-01-21 12:05:16.000000. File last date-time: 2025-01-21 12:05:16.000000 2025-01-21 12:16:54.725 | HD Request # 7 | Using server: ds32.sierracharts.com port 10150 2025-01-21 12:16:54.748 | Socket (4) | Creating socket. 2025-01-21 12:16:54.748 | Socket (4) | New receive buffer size: 0 2025-01-21 12:16:54.748 | Socket (4) | Connecting to IP: 67.214.125.3. 2025-01-21 12:16:54.757 | Socket (3) | Socket gracefully closed by remote side. 2025-01-21 12:16:54.757 | Socket (3) | Closed. 2025-01-21 12:16:54.862 | HD Request # 7 | Setting DTC encoding to Binary VLS 2025-01-21 12:16:54.862 | HD Request # 7 | Sending historical data logon request message. 2025-01-21 12:16:54.955 | HD Request # 7 | Requesting Intraday data. Start date-time: 2025-01-21 12:05:16. Record interval: 1. Symbol: CLH25 2025-01-21 12:16:55.007 | HD Request # 7 | Decompressing data. 2025-01-21 12:16:55.062 | HD Request # 7 | Receiving Intraday data for CLH25_FUT_CME starting at 2025-01-21 12:05:16.515000 2025-01-21 12:16:55.062 | Socket (4) | CloseSocket call. 2025-01-21 12:16:55.063 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-01-21 12:16:55.063 | Historical data download thread signaled to stop. 2025-01-21 12:16:55.063 | HD Request # 7 | Timestamp of first Intraday data file record written: 2025-01-21 12:05:16.515000. 2025-01-21 12:16:55.063 | HD Request # 7 | Received 451 Intraday data records from 2025-01-21 12:05:16.515000 to 2025-01-21 12:16:51.000000 (11.6 minutes. Delay: 4.1 seconds) and wrote 451 records for CLH25_FUT_CME 2025-01-21 12:16:55.069 | HD Request # 7 | Add time&sales data | Remembered last file record date-time: 2025-01-21 19:16:51.000000 2025-01-21 12:16:55.069 | Added 1 Time and Sales records to Intraday data file for CLH25_FUT_CME after download. 2025-01-21 12:16:55.069 | HD Request # 7 | Completion time: 1s. 2025-01-21 12:16:55.069 | HD Request # 7 | Intraday data download complete for CLH25_FUT_CME. Unique request ID: 2 2025-01-21 12:16:55.069 | Removing historical data download ID 2. 2025-01-21 12:16:55.069 | Real-time Intraday chart data file updates started for CLH25_FUT_CME 2025-01-21 12:16:55.075 | Opened cached Intraday file: C:\Users\lbowe\OneDrive\Sierra Charts\Data\CLH25_FUT_CME.scid. Thread ID: 153688 2025-01-21 12:16:55.075 | Intraday chart data file opened for CLH25_FUT_CME 2025-01-21 12:16:55.075 | HD Request # 7 | Enabling Intraday chart updating for symbol. 2025-01-21 12:16:55.075 | 2025-01-21 12:16:55.075 | Triggering next historical data download in queue. 2025-01-21 12:16:55.075 | HD Request # 8 | Downloading Intraday chart data for NQH25_FUT_CME to the file NQH25_FUT_CME.scid. Service: cme 2025-01-21 12:16:55.075 | HD Request # 8 | Download start date-time: 2025-01-21 12:05:17.000000. File last date-time: 2025-01-21 12:05:17.000000 2025-01-21 12:16:55.075 | HD Request # 8 | Using server: ds26.sierracharts.com port 10149 2025-01-21 12:16:55.101 | Socket (3) | Creating socket. 2025-01-21 12:16:55.101 | Socket (3) | New receive buffer size: 0 2025-01-21 12:16:55.101 | Socket (3) | Connecting to IP: 64.152.155.17. 2025-01-21 12:16:55.117 | Socket (4) | Socket gracefully closed by remote side. 2025-01-21 12:16:55.117 | Socket (4) | Closed. 2025-01-21 12:16:55.213 | HD Request # 8 | Setting DTC encoding to Binary VLS 2025-01-21 12:16:55.213 | HD Request # 8 | Sending historical data logon request message. 2025-01-21 12:16:55.308 | HD Request # 8 | Requesting Intraday data. Start date-time: 2025-01-21 12:05:17. Record interval: 1. Symbol: NQH25 2025-01-21 12:16:55.361 | HD Request # 8 | Decompressing data. 2025-01-21 12:16:55.418 | HD Request # 8 | Receiving Intraday data for NQH25_FUT_CME starting at 2025-01-21 12:05:17.123000 2025-01-21 12:16:55.418 | Socket (3) | CloseSocket call. 2025-01-21 12:16:55.419 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-01-21 12:16:55.419 | Historical data download thread signaled to stop. 2025-01-21 12:16:55.419 | HD Request # 8 | Timestamp of first Intraday data file record written: 2025-01-21 12:05:17.123000. 2025-01-21 12:16:55.419 | HD Request # 8 | Received 655 Intraday data records from 2025-01-21 12:05:17.123000 to 2025-01-21 12:16:52.081000 (11.6 minutes. Delay: 3.3 seconds) and wrote 655 records for NQH25_FUT_CME 2025-01-21 12:16:55.426 | HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2025-01-21 19:16:52.081000 2025-01-21 12:16:55.426 | Added 3 Time and Sales records to Intraday data file for NQH25_FUT_CME after download. 2025-01-21 12:16:55.426 | HD Request # 8 | Completion time: 0s. 2025-01-21 12:16:55.426 | HD Request # 8 | Intraday data download complete for NQH25_FUT_CME. Unique request ID: 3 2025-01-21 12:16:55.426 | Removing historical data download ID 3. 2025-01-21 12:16:55.426 | Real-time Intraday chart data file updates started for NQH25_FUT_CME 2025-01-21 12:16:55.430 | Opened cached Intraday file: C:\Users\lbowe\OneDrive\Sierra Charts\Data\NQH25_FUT_CME.scid. Thread ID: 153688 2025-01-21 12:16:55.430 | Intraday chart data file opened for NQH25_FUT_CME 2025-01-21 12:16:55.430 | HD Request # 8 | Enabling Intraday chart updating for symbol. 2025-01-21 12:16:55.430 | 2025-01-21 12:16:55.430 | Triggering next historical data download in queue. 2025-01-21 12:16:55.430 | HD Request # 9 | Downloading Intraday chart data for ESH25_FUT_CME to the file ESH25_FUT_CME.scid. Service: cme 2025-01-21 12:16:55.430 | HD Request # 9 | Download start date-time: 2025-01-21 12:05:17.000000. File last date-time: 2025-01-21 12:05:17.000000 2025-01-21 12:16:55.430 | HD Request # 9 | Using server: ds28.sierracharts.com port 10150 2025-01-21 12:16:55.430 | Socket (4) | Creating socket. 2025-01-21 12:16:55.431 | Socket (4) | New receive buffer size: 0 2025-01-21 12:16:55.431 | Socket (4) | Connecting to IP: 67.214.125.5. 2025-01-21 12:16:55.475 | Socket (3) | Socket gracefully closed by remote side. 2025-01-21 12:16:55.475 | Socket (3) | Closed. 2025-01-21 12:16:55.539 | HD Request # 9 | Setting DTC encoding to Binary VLS 2025-01-21 12:16:55.539 | HD Request # 9 | Sending historical data logon request message. 2025-01-21 12:16:55.632 | HD Request # 9 | Requesting Intraday data. Start date-time: 2025-01-21 12:05:17. Record interval: 1. Symbol: ESH25 2025-01-21 12:16:55.693 | HD Request # 9 | Decompressing data. 2025-01-21 12:16:55.747 | HD Request # 9 | Receiving Intraday data for ESH25_FUT_CME starting at 2025-01-21 12:05:17.131000 2025-01-21 12:16:55.747 | Socket (4) | CloseSocket call. 2025-01-21 12:16:55.747 | Socket (4) | Shutdown started. Waiting for graceful close. 2025-01-21 12:16:55.747 | Historical data download thread signaled to stop. 2025-01-21 12:16:55.748 | HD Request # 9 | Timestamp of first Intraday data file record written: 2025-01-21 12:05:17.131000. 2025-01-21 12:16:55.748 | HD Request # 9 | Received 569 Intraday data records from 2025-01-21 12:05:17.131000 to 2025-01-21 12:16:52.080000 (11.6 minutes. Delay: 3.7 seconds) and wrote 569 records for ESH25_FUT_CME 2025-01-21 12:16:55.753 | HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2025-01-21 19:16:52.080000 2025-01-21 12:16:55.753 | Added 3 Time and Sales records to Intraday data file for ESH25_FUT_CME after download. 2025-01-21 12:16:55.753 | HD Request # 9 | Completion time: 0s. 2025-01-21 12:16:55.753 | HD Request # 9 | Intraday data download complete for ESH25_FUT_CME. Unique request ID: 4 2025-01-21 12:16:55.753 | Removing historical data download ID 4. 2025-01-21 12:16:55.753 | Real-time Intraday chart data file updates started for ESH25_FUT_CME 2025-01-21 12:16:55.757 | Opened cached Intraday file: C:\Users\lbowe\OneDrive\Sierra Charts\Data\ESH25_FUT_CME.scid. Thread ID: 153688 2025-01-21 12:16:55.757 | Intraday chart data file opened for ESH25_FUT_CME 2025-01-21 12:16:55.757 | HD Request # 9 | Enabling Intraday chart updating for symbol. 2025-01-21 12:16:55.757 | 2025-01-21 12:16:55.757 | Triggering next historical data download in queue. 2025-01-21 12:16:55.757 | HD Request # 10 | Downloading Intraday chart data for YMH25_FUT_CME to the file YMH25_FUT_CME.scid. Service: cbot 2025-01-21 12:16:55.758 | HD Request # 10 | Download start date-time: 2025-01-21 12:05:17.000000. File last date-time: 2025-01-21 12:05:17.000000 2025-01-21 12:16:55.758 | HD Request # 10 | Using server: ds32.sierracharts.com port 10149 2025-01-21 12:16:55.758 | Socket (3) | Creating socket. 2025-01-21 12:16:55.758 | Socket (3) | New receive buffer size: 0 2025-01-21 12:16:55.758 | Socket (3) | Connecting to IP: 67.214.125.3. 2025-01-21 12:16:55.804 | Socket (4) | Socket gracefully closed by remote side. 2025-01-21 12:16:55.804 | Socket (4) | Closed. 2025-01-21 12:16:55.865 | HD Request # 10 | Setting DTC encoding to Binary VLS 2025-01-21 12:16:55.865 | HD Request # 10 | Sending historical data logon request message. 2025-01-21 12:16:55.959 | HD Request # 10 | Requesting Intraday data. Start date-time: 2025-01-21 12:05:17. Record interval: 1. Symbol: YMH25 2025-01-21 12:16:56.014 | HD Request # 10 | Decompressing data. 2025-01-21 12:16:56.089 | HD Request # 10 | Receiving Intraday data for YMH25_FUT_CME starting at 2025-01-21 12:05:17.161000 2025-01-21 12:16:56.089 | Socket (3) | CloseSocket call. 2025-01-21 12:16:56.089 | Socket (3) | Shutdown started. Waiting for graceful close. 2025-01-21 12:16:56.089 | Historical data download thread signaled to stop. 2025-01-21 12:16:56.090 | HD Request # 10 | Timestamp of first Intraday data file record written: 2025-01-21 12:05:17.161000. 2025-01-21 12:16:56.090 | HD Request # 10 | Received 313 Intraday data records from 2025-01-21 12:05:17.161000 to 2025-01-21 12:16:52.071000 (11.6 minutes. Delay: 4.0 seconds) and wrote 313 records for YMH25_FUT_CME 2025-01-21 12:16:56.095 | HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2025-01-21 19:16:52.071000 2025-01-21 12:16:56.095 | Added 1 Time and Sales records to Intraday data file for YMH25_FUT_CME after download. 2025-01-21 12:16:56.095 | HD Request # 10 | Completion time: 1s. 2025-01-21 12:16:56.095 | HD Request # 10 | Intraday data download complete for YMH25_FUT_CME. Unique request ID: 5 2025-01-21 12:16:56.095 | Removing historical data download ID 5. 2025-01-21 12:16:56.095 | Real-time Intraday chart data file updates started for YMH25_FUT_CME 2025-01-21 12:16:56.098 | Opened cached Intraday file: C:\Users\lbowe\OneDrive\Sierra Charts\Data\YMH25_FUT_CME.scid. Thread ID: 153688 2025-01-21 12:16:56.098 | Intraday chart data file opened for YMH25_FUT_CME 2025-01-21 12:16:56.098 | HD Request # 10 | Enabling Intraday chart updating for symbol. 2025-01-21 12:16:56.098 | 2025-01-21 12:16:56.098 | No download requests in the queue to start downloads for. 2025-01-21 12:16:56.165 | Socket (3) | Socket gracefully closed by remote side. 2025-01-21 12:16:56.165 | Socket (3) | Closed. 2025-01-21 12:16:56.945 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request. 2025-01-21 12:16:57.278 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2025-02-17"}. Success=true 2025-01-21 12:19:40.347 | YMH25_FUT_CME[M] Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | Number times message added: 1 2025-01-21 12:25:56.539 | ESH25_FUT_CME[M] 5 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 | Number times message added: 1 2025-01-21 12:26:11.248 | NQH25_FUT_CME[M] Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | Number times message added: 1 2025-01-21 12:26:19.110 | Saved Chartbook: YM Chartbook.Cht. Time: 0.0099 seconds. 2025-01-21 12:26:19.118 | Saved Chartbook: ES Chartbook.Cht. Time: 0.0078 seconds. 2025-01-21 12:26:19.133 | Saved Chartbook: NQ Chartbook.Cht. Time: 0.0137 seconds. 2025-01-21 12:26:19.143 | Saved Chartbook: GC Chartbook.Cht. Time: 0.0094 seconds. 2025-01-21 12:26:19.150 | Saved Chartbook: CL Chartbook.Cht. Time: 0.0066 seconds. 2025-01-21 13:50:32.573 | ESH25_FUT_CME[M] Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 | Number times message added: 1 2025-01-21 14:01:44.644 | GCG25_FUT_CME[M] Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:01:44.729 | GCG25_FUT_CME[M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:01:44.730 | CLH25_FUT_CME[M] Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:01:44.730 | ESH25_FUT_CME[M] Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:01:44.733 | YMH25_FUT_CME[M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:01:44.838 | YMH25_FUT_CME[M] Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:01:44.844 | CLH25_FUT_CME[M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:01:44.845 | ESH25_FUT_CME[M] 5 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:01:44.980 | NQH25_FUT_CME[M] Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:07:56.111 | NQH25_FUT_CME[M] Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:07:56.642 | GCG25_FUT_CME[M] Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:07:56.718 | GCG25_FUT_CME[M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:07:56.718 | CLH25_FUT_CME[M] Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:07:56.720 | ESH25_FUT_CME[M] Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:07:56.723 | YMH25_FUT_CME[M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:07:56.822 | YMH25_FUT_CME[M] Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:07:56.828 | CLH25_FUT_CME[M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:07:56.829 | ESH25_FUT_CME[M] 5 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:37:45.414 | GCG25_FUT_CME[M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:37:45.414 | CLH25_FUT_CME[M] Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:37:45.414 | ESH25_FUT_CME[M] Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:37:45.421 | YMH25_FUT_CME[M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:37:45.456 | YMH25_FUT_CME[M] Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:37:45.459 | CLH25_FUT_CME[M] 5 Min #1 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:37:45.460 | ESH25_FUT_CME[M] 5 Min #4 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:37:45.832 | NQH25_FUT_CME[M] Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 2025-01-21 14:37:46.362 | GCG25_FUT_CME[M] Flex Renko 10-7-0 #3 | StartDateTimeForLoadingOrderFills: 00:00:00 |
| [2025-01-22 16:50:15] |
There is nothing in the log that shows any issues. Can you please get us an image of both situations for the same chart. One image where the [M] is showing and another where it is not. Follow these instructions to get us images: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-01-23 14:57:09] |
https://www.sierrachart.com/image.php?Image=1737644030477.png https://www.sierrachart.com/image.php?Image=1737644150342.png |
| [2025-01-24 13:37:31] |
Username: Lmbower43 | Ticket ID: 1737468026296 | Status: Open | Subject: The [M] is not staying on. John: See above for copies of the (2) entire Chart; showing NO [M]; and the other showing the [M]. When I open Program the [M} is not visible; I go to Chart>Chart> and click Automatically Rollover to Yes, then NO and then back to YES; then Apply and OK then the [M] it in place. But Can not make it stay on. |
| [2025-01-24 23:54:27] |
| Sierra_Chart Engineering - Posts: 25060 |
Are you seeing any other issue, other than the [M] not displaying.
