Date/Time: Tue, 22 Apr 2025 10:17:24 +0000
DOM's Scale Horizontal Lines out of place after update
View Count: 143
[2025-01-21 16:12:01]
Rui S - Posts: 199
Hello support,
I've just updated one of my platforms from version 2692 to the latest version and now the DOM's scale's horizontal lines are out of place and I can't figure out how to get them back to the desired levels.
Wil you please give me instructions for what I should do to correct it?
Date Time Of Last Edit: 2025-01-21 16:13:32
image002.jpg / V - Attached On 2025-01-21 16:13:28 UTC - Size: 136.74 KB - 40 views
[2025-01-21 18:59:01]
John - SC Support - Posts: 39395
We apologize for this. We made a change in the last release to try and correct an older problem with the Horizontal grid and it caused this problem. The next Pre-Release that comes out (v 2734) will have the grid back to the way it used to be and we will work on fixing the older issue another time.
