Date/Time: Sun, 04 Oct 2026 17:02:09 +0000
Trade activity Log
View Count: 1257
[2014-09-17 15:28:41]
User82486 - Posts: 43
After placing and closing SIMULATED trades the Activities Lof for Simulated trades is blank. How can I get a simple r3ecord of the buys and sells that were made?
Fred
[2014-09-17 17:05:53]
Most likely you have a setting at the top of the Trade Activity Log which is not correct.
Follow the step-by-step instructions here:
https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#ViewingHistoricalTA
[2014-09-25 20:25:53]
User12167 - Posts: 16
Hi - I'm having the same problem.
Cleared all simulated data.
Placed several trades.
Orders & Positions shows trades.
Trade activity log does not.
imagesim.jpg / V - Attached On 2014-09-25 20:24:29 UTC - Size: 385.8 KB - 450 views
[2014-09-25 20:49:02]
At the top of the Trade Activity Log there is a list box that lists symbols. You need to select a symbol.
[2014-09-25 21:01:43]
Yes that did it thanks. Not sure why there is a blank row though.. Any idea? IMHO it would be good for the default view to show all symbols.
imageactivititylog.jpg / V - Attached On 2014-09-25 21:01:06 UTC - Size: 84.29 KB - 492 views
[2014-09-25 21:09:57]
The blank Symbol is for server connection activity lines which apply to all symbols.
Date Time Of Last Edit: 2014-09-25 21:10:14
