Date/Time: Wed, 19 Mar 2025 02:42:09 +0000
Can not get real time ES data
View Count: 108
[2025-01-21 13:59:20] |
ghost_in_shell - Posts: 4 |
Hi I have subscribed to the CME service bundle to trade ES, but I'm not getting real time data, for example ESH25-CME is not feeding. I've connected my IB account to the Sierra Chart but it still does not work. Can you help with this issue? Thanks in advance. |
Private File |
[2025-01-21 18:24:31] |
John - SC Support - Posts: 38782 |
Everything on your account looks good. And we do not see anything in the image you provided that makes us think that the data is delayed. If you still think you are having an issue with the data for ES, then we would need to see your Message Log by following these instructions: Follow the instructions here to clear the Message Log:
Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
