Date/Time: Wed, 19 Mar 2025 03:48:57 +0000
Denali feed still showing as trial
View Count: 118
[2025-01-21 11:32:34]
G0ldDigger - Posts: 5
Hi there,
Trying to figure out how to get my new denali realtime data feed working. I swear I read the docs and am sure I am missing something somehow. Anyways, I have stage 5. I have activated the service. I believe I did fund it $100 (I am just using them to keep the account verified). Stage 5 said they will check on the funding. So not sure if that part matters yet. The denali feed is activated in sierra chart (from what I see). However, the data for /ES still says delayed. I am wondering if I am supposed to choose something under File/Data Trade Service Settings (see attached). I am not sure which to choose.
Thanks.
imagedata service setting.png / V - Attached On 2025-01-21 11:32:09 UTC - Size: 33.06 KB - 35 views
[2025-01-21 15:09:32]
Sierra_Chart Engineering - Posts: 18837
You have done everything correctly except for:
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services".
Press "OK"
And then translate the symbols in your Chartbooks in Sierra Chart using this "Edit' menu command:
Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service)
You can then use the data provided by Sierra Chart independent of your trading service.
Also this does matter:
Your account does need to be set up on Teton order routing by them. When this is done, by the next morning you should be getting real-time data.
Date Time Of Last Edit: 2025-01-21 15:13:44
