Date/Time: Tue, 22 Apr 2025 10:23:22 +0000
Create a space between DOM graph on chart and Values Scale to use labels on right edge.
View Count: 228
[2025-01-20 12:49:05] |
noStopLoss - Posts: 6 |
Hi there, I'm currently using the DOM graph on chart (as attached) but was wondering if it's possible to create a space between the DOM Graph and the Right Side Values Scale, so that I'm able to put Labels on the Right Edge without blocking the dom graph |
[2025-01-20 13:23:36] |
Sierra_Chart Engineering - Posts: 19305 |
No, this is not supported.
[2025-01-20 14:10:59] |
Sébastien - Posts: 58 |
Is it what you are trying to achieve ? (see attached file)
[2025-01-20 14:29:53] |
@Sébastien yes, that's exactly what i'm trying to achieve. Any help would be greatly appreciated!
[2025-01-20 16:23:43] |
Ok then simply do this on your chart : - Activate DOM graph (Trade => Draw DOM Graph On Chart) - Activate Market data columns (Trade => Show Market Data Column) - Customize maket data columns (Trade => Customize Chart/Trade DOM Columns) Add Combined Bid/Ask Size Add Label Column - To show your studies' labels in the Label Column, just go to the subgraph tab of each of your studies and select Horizontal Align : Label Column |
[2025-01-21 07:15:27] |
Thank you for the information in post #5.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-21 07:15:45
