Date/Time: Tue, 22 Apr 2025 10:17:24 +0000
Footprint Blank Spaces
View Count: 218
[2025-01-20 10:33:08]
User110225 - Posts: 23
Hi
My footprint chart for 6b is randomly not printing some of the horizontal bid/offer figures, instead I just have a blank box. There does not appear to be a pattern to this, sometimes its the high of the bar, the low of the bar, or in the middle of the bar. Some bars have no blanks, some a have 1 blank and others have multiple blanks at different price levels.
I am trading renko bars (ticks). Changing the tick setting doesn't solve the problem.
I have updated to the latest SC release and I have searched for solution but I am now struggling.
Any help would be greatly appreciated.
Best wishes
Chris
[2025-01-20 13:23:00]
Sierra_Chart Engineering - Posts: 19305
Provide an image of the chart or Trade DOM, by following these *exact* instructions:
[2025-01-20 14:27:38]
https://www.sierrachart.com/image.php?Image=1737383195742.png
[2025-01-20 22:47:26]
This could be normal.
Make sure you have disabled Volume filtering:
Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu)
[2025-01-21 16:39:55]
Thank you.
I have the volume filter setting set to
Exclude >= 0
Exclude <= 0
Filter Trade Completely No
Do you have any other suggestions, this has only recently become an issue for me and it makes my analysis difficult as I like to use ratios and turning points, obviously when I have no numbers I cant calculate the ratios.
Thanks for all of your help.
Chris
[2025-01-21 19:14:01]
John - SC Support - Posts: 39395
This is going to be a particular issue since you are using Renko bars. But even with tiem basded bars we do see this still occurring with this instrument.
[2025-01-21 19:22:25]
Thanks John.
No worries I shall just work around it
All the best
Chris
