Date/Time: Tue, 22 Apr 2025 10:26:18 +0000
Software bug
View Count: 173
[2025-01-20 09:47:21] |
Serajeddean - Posts: 5 |
Hello, hoping this message finds you in good health. I noticed a strange bug on the software, when I make a change on my chart or add a box or just anything, and close down the system with save close, and reboot again it did not save anything from last time I closed it with save yes option selected. Is it just me? How do I fix it and ensure my charts are saved and so I don't have to redo everything again and saves properly? Kind regards, Seraj. |
[2025-01-20 22:55:54] |
Sierra_Chart Engineering - Posts: 19305 |
There could not be a problem with this. Before exiting Sierra Chart, select this command: File Menu: Save All (File) And make sure this is enabled: General Settings Window: Display Save All Option on Exit (Global Settings >> General Settings >> GUI >> Application GUI) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-20 22:56:05
