Date/Time: Tue, 22 Apr 2025 07:40:08 +0000
mapping to micro 10yr ultra treasury bond future
View Count: 339
[2025-01-19 22:40:17] |
User12089 - Posts: 365 |
Hello, not having luck mapping the micro 10yr ultra treasury bind future for when the execution/trade service is CQG - ref the attached image That mapping seems to be missing in the standard SC mappings which cover the 10yr ultra but not the micro version Also note that when the data service is SC DAta the micro version is available / supplied by Denali and my SC SQG Data Feed is with SC Data support checkbox enabled Date Time Of Last Edit: 2025-01-19 22:41:21
[2025-01-20 23:11:38] |
Sierra_Chart Engineering - Posts: 19297 |
F.US.MTNA is the CQG symbol, for micro 10 year ultra treasury futures?
[2025-01-21 14:46:37] |
yes
[2025-01-21 15:51:36] |
and btw there is also micro ultra 30yr - if u are doing anything at the serverside of Denali for the micro ultra 10yr, please also do the same for the 30yr
[2025-01-23 15:27:45] |
hello folks, any porgress here?
[2025-01-26 22:27:53] |
F.US.MTNA is now added. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
