Date/Time: Tue, 22 Apr 2025 10:20:21 +0000
problem with keyboard shortcuts
View Count: 119
[2025-01-19 14:24:42]
User282565 - Posts: 12
Hello, i wanted to set up keyboard shortcuts for Buy MKT and Sell MKT.
I selcted for Buy MKT A as a shortcut and clicked on assign and then ok.
But it did not work when i tried it. I watched some YouTube videos and did it
the exact same way. My keyboard works. Please help me to find a solution for
this problem. Thanks
[2025-01-19 21:21:53]
Sierra_Chart Engineering - Posts: 19305
So you assigned the letter A for the shortcut? We tried this and it does work.
Refer to:
Global Settings Menu: Keyboard Shortcuts Not Functioning
Date Time Of Last Edit: 2025-01-19 21:22:02
[2025-01-21 17:30:32]
John - SC Support - Posts: 39395
Note that it is never a good idea to assign a keyboard shortcut to a single alphanumeric character. That character could then be interpreted as keyboard input instead of a keyboard shortcut. You should always use a modifier key in addition to a single character.
