Date/Time: Tue, 22 Apr 2025 10:20:21 +0000
How to adjust text side for custom study values
View Count: 158
[2025-01-19 03:21:02]
cmack1011 - Posts: 89
I have a study that is using a draw style of "Transparent Custom Value at Y Left Aligned" (please see attached pic). As you can see in the graph at the bottom of the pic, the values are so small that they are unreadable. Is there a way to increase the font size? I have looked throughout the chart and global graphic options but I could not find an option that worked. Thank you.
Date Time Of Last Edit: 2025-01-19 03:24:08
imageScreenshot 2025-01-18 at 9.14.24 PM.png / V - Attached On 2025-01-19 03:19:58 UTC - Size: 98.92 KB - 49 views
[2025-01-19 09:35:08]
User431178 - Posts: 654
Subgraph text size is set by width/size input.
Chart Studies: Custom Value At Y (ACSIL: DRAWSTYLE_CUSTOM_VALUE_AT_Y)
