Date/Time: Tue, 22 Apr 2025 10:20:22 +0000
Changing font for numbers bars text
View Count: 244
[2025-01-18 15:25:18]
HeyUgly - Posts: 251
experienced user here, for years
Something has happened. Ive checked global settings - font is set to what i want
Checked number bar chart graphics setting, its set correctly to what i want - its selected to use the proper settings {box at top}
but suddenly when i restarted sierra, the font for the numbers changed. I font selected though, is correct but not showing.
Is there a seperate font selection option inside the number bars settings that ive never seen? Ive never encountered this problem and ive built hundreds of chartbooks
Everything is bold, and the font displaying is wrong. Even though the font selected is regular style and is not being displayed.
Ive triple checked everything and cannot figure it out.
[2025-01-18 15:28:18]
for example
here is the number bar
it will change in size etc
but you can see "regular" is selected, but all number bars are in bold and will not change back to regular.
imageCapture.PNG / V - Attached On 2025-01-18 15:28:07 UTC - Size: 14.96 KB - 64 views
[2025-01-19 18:58:41]
cmet - Posts: 690
Probably not it but check the Bid Ask bold threshold in Numbers Bars. Make sure it's 0.
imageNumBar bold.jpg / V - Attached On 2025-01-19 18:58:37 UTC - Size: 13.07 KB - 40 views
[2025-01-21 10:06:11]
ticinotrader - Posts: 412
@HeyUgly
Since this is a chartbook from me, feel free to message me through my site or directly via email, and I’ll do my best to help resolve this.
