Date/Time: Tue, 22 Apr 2025 10:23:19 +0000
Commission not included in trade activity log
View Count: 162
[2025-01-18 08:59:53] |
sabbers - Posts: 27 |
I use Tradervue for journaling. After importing the file commissions are not visible. Instrument is ES. I added a value for Global round turn commission under global settings -> symbol settings and checked the box Display settings in the trader log menu is selected yes for commissions. In the export file i do not see a commissions column. Any tips? |
[2025-01-18 19:50:12] |
Sierra_Chart Engineering - Posts: 19305 |
This is definitively not supported. When you are exporting Trade Activity data, it is just the unaltered order fill data. There are no commissions at all.
