Date/Time: Tue, 22 Apr 2025 10:23:20 +0000
Data Latency
View Count: 220
[2025-01-18 02:40:33] |
User923944 - Posts: 8 |
I am experiencing slow price movements on my charts--sometimes a second or so will pass before a movement, and then a jump in price for three or more ticks. I am aware of the Sierrachart web page on correcting poor performance and high CPU usage, and have made the adjustments that seem pertinent such as using a small number of days of data to load, adjusting chart update interval, eliminating unneeded charts, eliminating charts referring to other charts, and uninstalling anti-virus software. I have created a separate chartbook with only one chart with a simple numbers bar setup and no volume at price study, tested it with nothing else open, and still have the same issue. Have compared various settings with another user who does not have this issue, and find no differences. Can you suggest further steps? Thanks |
[2025-01-18 04:07:03] |
Sierra_Chart Engineering - Posts: 19305 |
Refer to help topic 4: Prices / Data Falling Behind And use Sierra Chart timers: General Settings Window: Use OS Timer for Charts (Global Settings >> General Settings >> General >> Update Intervals) By setting this to No Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-18 04:07:16
