Date/Time: Fri, 11 Sep 2026 23:05:43 +0000
Pivot Points Daily acsil code not compiling
View Count: 1745
| [2014-09-17 11:35:04] |
| Hendrixon - Posts: 130 |
It gives this error: C:\Windows\cc3lOXH9.o:my_Pivot_Points_Daily_Lower_Processing.cpp:(.text+0x82b): undefined reference to `CalculateDailyPivotPoints(s_sc&, int, int, int, SCGraphData&, SCDateTimeArray&, int, int, int, int, float, float, float, float, int, float&, float&, float&, float&, float&, float&, float&, float&, float&, float&, float&, float&, float&, float&, float&, float&, float&, float&, float&)' collect2.exe: error: ld returned 1 exit status The code unchanged taken from studies7.cpp |
| [2014-09-17 17:26:40] |
You also need to include this function in your source code file: CalculateDailyPivotPoints It is located in SCStudyFunctions.cpp Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2014-09-17 22:28:51] |
Only After I copied both "CalculateDailyPivotPoints" and "CalculatePivotPoints" into my source code, it compiled. But shouldn't the following statements do the work without the need to copy whole functions? #include "sierrachart.h" #include "scstudyfunctions.h" |
| [2014-09-17 22:38:15] |
No. You do have to copy those functions as well.
