Date/Time: Tue, 22 Apr 2025 07:02:55 +0000
Profile Interactive Tool
View Count: 202
[2025-01-17 15:03:30]
User964033 - Posts: 5
Hi there,
Is possible to filter DOM's Current Total Traded Volume using Profile Interactive Tool (Service Package 11)?
So to -> Accumulate only volume, lets say, greater 100 or so.
Thank you.
[2025-01-17 17:05:22]
John - SC Support - Posts: 39395
We are not sure what exactly you are wanting to do. The "Drawn Volume Profile" option has no impact on the Current Total Traded Volume columns.
The only way to filter the Current Traded Total Volumes would be to filter entire trades from the chart. Refer to the following:
Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu)
[2025-01-20 00:52:19]
This is what I meant:
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=113741
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=113742
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=113743
imageDOM Trader Settings Filt. Volume.jpg / V - Attached On 2025-01-20 00:45:53 UTC - Size: 55.02 KB - 53 views
imageDOM Trader Settings Filt. Volume Set to 256.jpg / V - Attached On 2025-01-20 00:46:19 UTC - Size: 48.65 KB - 41 views
imageDOM Trader With Filt. Volume Set to Accomulate Vol 256 or mo.jpg / V - Attached On 2025-01-20 00:46:50 UTC - Size: 140.16 KB - 48 views
[2025-01-21 07:13:49]
Sierra_Chart Engineering - Posts: 19293
Add the Volume by Price study to the Trading DOM:
Volume By Price Study
You will want to use this Volume Graph Period Type:
Volume By Price Study: From Session Start Time to End
Volume By Price Study: Volume Graph Period Type
And you can control the volume filtering in the chart:
Date Time Of Last Edit: 2025-01-21 07:14:17
[2025-01-31 14:13:17]
Thank you!
Does DOM have Trades (Number of Trades) columns/study or whatever?
Thx
[2025-01-31 15:43:58]
DOM Trades (Number of Trades)
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=114569
imageDOMTrades.jpg / V - Attached On 2025-01-31 15:40:53 UTC - Size: 152.35 KB - 38 views
[2025-01-31 16:56:26]
Actual number of trades that have occurred at a price level - no. You would need to use the Volume by Price study to get this information.
If you want the number of trades that make up the Bid/Ask Market Depth, then refer to the following:
Global Trade Settings Windows: Bid Number of Orders - Left/Center/Right Aligned
