Date/Time: Mon, 15 Dec 2025 09:10:56 +0000
Chartbook File
View Count: 267
| [2025-01-17 14:10:32] |
| User841161 - Posts: 315 |
I am getting this message when opening my Sierra Chart. 2025-01-17 08:05:22.132 | The Chartbook file is not compatible. Contact Sierra Chart support for help with converting it. File: C:\SierraChart\SierraChartInstance_4\Data\ExampleChartbook.cht * |
| [2025-01-17 17:35:03] |
| John - SC Support - Posts: 43443 |
If this is a chartbook you have not used in a long time then refer to the following: Chartbooks (Workspaces): Opening Older Chartbooks If this is a chartbook you have been using and you just suddenly are getting this message, then that chartbook is corrupted for some reason. In this case, you will need to restore a backup of the chartbook by following these instructions: Chartbooks (Workspaces): Accessing a Backup Chartbook File For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
