Date/Time: Tue, 22 Apr 2025 10:23:21 +0000
front month CNHG25-CME future corrupt price
View Count: 230
[2025-01-17 10:36:16]
weav - Posts: 44
Hi
Just tried to load historical data on Denali (SC Data - All Services) for this instrument and the current price is 734 million (17th Jan). Prior settle (16th Jan) was 7.3405
CNHG25.dly is fine but no row for 17th Jan. Last row is 16th. Tried deleting and re-downloading but same result. Can you have a look pls ?
thank you
imageScreenshot 2025-01-17 103412.png / V - Attached On 2025-01-17 10:35:34 UTC - Size: 20.84 KB - 53 views
[2025-01-17 16:52:22]
John - SC Support - Posts: 39395
Check the settings for the "Real-Time Price Multiplier" and "Historical Price Multiplier". Make sure these are both set to "1". Refer to the following and the item below it:
Chart Settings: Real-Time Price Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
[2025-01-17 17:37:17]
weav - Posts: 44
Both are 1, still the same issue
[2025-01-17 19:08:08]
Sierra_Chart Engineering - Posts: 19305
We are checking on this.
[2025-01-20 22:04:13]
This is resolved.
After this re-download the data in the chart:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download" from the main Sierra Chart menu. You just need to do this once per symbol and not for each chart. This command is on the main Sierra Chart menu at the top. Only use it from that location.
